Creating a Shortcut direct to a control panel sub-level window
I find that I'm wanting to change the Microphone level quite often and wonder if I can somehow create a shortcut direct to it, so it's a 1-click thing, straight to the Levels tab.
Currently I have to click about 7 times to get to that tab. Is it possible to create a shortcut to a drilled down level like that? If not, does anyone know if there's a way to find where in the registry the Level number is stored ? Then I can at least create a few preset .reg files that I can click on to set it without even going into that Levels dialog.
