Audio Jack not working, but USB Audio is.
  1. Posts : 87
    My self built computer recently had a change of motherboard, I now have a Asrock N68C-GS FX.
    The front cases' and computers back audio jack are not working, I have tried numerous headphones and speakers.
    However my USB headset works perfectly. My drivers are all up to date, I'm struggling to think a reason why it's not working.
    Any help greatly appreciated.
    Thanks, lee.
  2. Posts : 5,915
    Windows 10 Pro X64
    I would check your motherboards connectors, check your manual for audio connections
  3. whs
    Did you check the default in 'Playback Devices'. Maybe it needs to be changed.
  4. Posts : 2,240
    Windows 7 Ultimate 64 bit
    Do you have the front panel usb connectors connected to the mobo usb headers and that they are the right headers?
    Are you sure you have all your mobo drivers installed, including the chipset driver?
  5. Posts : 87
    My motherboard is correctly set up, as I have had it checked of numerous people. When I click playback devices, neither jacks recognize any playback devices being installed, but when I plug my USB headset in it does.
  6. Posts : 5,915
    Windows 10 Pro X64
    Filling out your specs using the link in my sig, and posting a screenshot of device manager will help us help you.
  7. Posts : 87
    Sorry for the late reply, I have updated my Specs.
    Attached Thumbnails Attached Thumbnails Audio Jack not working, but USB Audio is.-untitled.png
  8. Posts : 5,915
    Windows 10 Pro X64
    Can you right click high definition audio device and show the properties/driver tab
  9. Posts : 5,915
    Windows 10 Pro X64
    If you are using the windows driver, I recommend you use the driver from asrock
    Asrock Drivers
  10. Posts : 87
    Here is the screen shot, I will download the driver now
