Volume Indicator (not icon) Disappeared - Windows 7 Professional
  1. Posts : 3
    Windows 7 Professional 64 Bit
    Recently, when I've been using audio, I have been controlling the volume from my keyboard, and when doing so, a little volume indicator appears while I am adjusting the volume and disappears when I stop adjusting it. However, it has disappeared during the last few days, which I don't understand. If anyone can offer advice on how to get it back, that would be greatly appreciated.
    Thanks!
  2. Posts : 18,415
    windows 7 home 64bit
    Hi there ... If you know the exact Model Number of your Dell Laptop .. You should be able to download the software that is needed to run that program .. It has to do with Hotkeys
  3. Posts : 3
    Thanks, any idea where to download it? I'm running a Latitude E6420, would I need any more specifics than that?
  4. Posts : 25,847
    This might help.
    Reboot your laptop. If this doesn't help go to a restore point before the problem happened.
  5. Posts : 18,415
    Give me a few moments .. And i shall see if i can find it
  6. Posts : 18,415
    The link below has the Drivers for your Laptop.. There is a lot of Software there .. Exactly which one you need is the problem
    Drivers & Downloads | Dell US
  7. Posts : 18,415
    Its the Dell Feature Enhancement Pack you need
  8. Posts : 1,007
    Winndows 7 32 bit
    Thanks!
    Hi codyfromcoby,
    Welcome to Seven forums.
    Please check the link below for downloading control point software which should resolve this issue:
    http://downloads.dell.com/FOLDER3533...IN_R312259.EXE
    Also, if it was working earlier then you can try system restore to reach earlier setting to resolve this issue:
    System Restore
    Keep us posted with the results so we can advise you further.
  9. Posts : 3
    Layback, thanks! Sometimes, the simplest answer is the easiest, the problem has been fixed with a restart! I appreciate the efforts from everyone else, though, thank you for your assistance!
  10. Posts : 18,415
    Glad you got it sorted .. And yes your right the simplest way is always the best
