You`d have to listen to the sub woofer and see how it sounds at that level, but I wouldn`t turn it up to 100%. It may destroy it.
Take baby steps in any kind of audio adjustment.
This from Dell:
Audio and Speakers
- JBL 2.1 Designed & Certified Speakers + Waves MaxxAudio® 3
2.1 Audio: 2 X 4W + 12W sub-woofer = 20W total peak audio performance
To get 5.1 surround sound, you would have to have six speakers: two front speakers, two rear speakers (impossible to build into a laptop), a center channel speaker, and a sub woofer. A system like that would require three cables plugged into three jacks on the laptop to feed it.
That said, you can always try gradually increasing the setting on the "subwoofer" (sorry, I'm having a hard time wrapping my old mind around the concept of a true subwoofer on a laptop) until you get the sound you want. Keep in mind a tiny "subwoofer" like that isn't going to give deep, thundering bass no matter where you set it.
Ive just read that the when maxaudio software is on the subwoofer is aswell but im not understanding if this windows 7 setting 100 could damage the subwoofer? Im mostly listen to music or watching videos and my speaker volume is 35. I would admit it you would notice a difference when its on and compared to laptops which does not have 1(tested with a vaio e series).
