Windows 7 64-bit Ult does not detect my sound card
  1. Posts : 9
    windows 7 ultimate
    hi all,
    i hav dual boot with win7 64-bit ultimate RC and win XP..... my windows 7 does not detect my sound card. when i try to install any drivers , i get a msg "Setup is unable to detect any supported product on ur system" [i tried many drivers]..In the Device manager, drivers for "Multimedia Audio Controller" & "PCI Simple communication controller" are not installed.. but no issues with win XP...pleassssssssssssssse help .... pls send me links
    Motherboard- intel Dg33tl - BQTL81000ES
    Sound Card - Creative Sound Blaster 5.1
    Intel Core 2 Duo 2.53 Ghz
    Speaker - Creative Sbs A500
  2. Posts : 6,879
    Win 7 Ultimate x64
    sujex, welcome to the forums.
    Your card is one of the few Creative cards that I know very little about,or what it really is. Could you pull the card and post back the model number that is on it, will look something SBxxxx. With that number I will be able to track down whether your SOL, or if there is possibly a modded driver set that will work with it in 7.
  3. Posts : 39
    Windows 7 Professional x64
  4. Posts : 1
    I had the same problem with my SB Audigy 2 card (on an Asus P5ND2 SE motherboard). Once I finally got it detected, my outbound sound worked fine, but my microphone stuttered in and out (I reportedly sounded like a dalek).
    I later found out that it was an incompatibility issue with my sound card, my motherboard and windows 7. I got a Creative USB sound blaster and it works fine.
    I did have the latest drivers from the creative auto updater so that wasn't the problem (Vista x64 drivers work 99 times out of 100 for 7 x64).
    I saw a table somewhere on the creative site with a list of all drivers for all sound cards and all OS from 2000 to Windows 7. (incl XP + Vista, both 32 and 64 bit)... but I can't find it anywhere now.
    My Audigy 2 is on the list of supported for Windows 7 but DOES NOT work unless you're happy sounding like a dalek with your microphone.
    This is all, hope it helps...
  5. Posts : 9
    windows 7 ultimate
    i was not able to check my sound card,, but i found my vendor ID and Device ID and checked in PCIdatabase.com and found the SB number,, hope this is helpful.
    vendor 1102
    Device 0006
    SB0200
  6. Posts : 8,870
    The Daniel K Audigy2 drivers work fine with Windows 7. The Creative Win 7 drivers make static noises and are just terrible, which is so very typical for Creative drivers.
    I had to get the Daniel K drivers by torrenting.
  7. Posts : 6,879
    Win 7 Ultimate x64
    sujex I think you will find that part of the problem is that your card originally came from Dell. Problem with the Dell cards is that they have a different DevID than the same card directly from Creative. If you can find it in Device Manager, get the full DevID for it. It will look something like this,
    %EMU10K1.DeviceDesc%=EMU10K1_Device,PCI\VEN_1102&DEV_0002&CC_040100
    and I can walk you through where to put it in the driver files (assuming it doesn't match the one already there.
    Not sure why you would need to torrent it, the links to the Creative forum posts for all of his drivers are here,
    Creative Sound Cards.
  8. Posts : 9
    windows 7 ultimate
    hi stormy 13,
    where to get tat?
    from device manager->details-> device id????
  9. Posts : 344
    Windows 7, Linux
    Google Daniel K or KX Project. Since their are now 501 SBL threads I'm just going to keep it simple. Google Daniel K or KX Project, I don't know how many times I have to repeat this a day, or even in a thread but all you do is:
    google Daniel K or KX Project, Either of those projects work for SBL and Audigy's....
    Daniel K or KX Project for the EMU10K1/EMU10K2 chipsets, or the SBL and Audigy's.
    KX Audio Drivers [emu10k1]
  10. Posts : 9
    windows 7 ultimate
    hi stormy 13,
    device instance path :
    PCI\VEN_1102&DEV_0006&SUBSYS_10011102&REV_00\4&768C482&0&00F0
    hardware ID's :
    PCI\VEN_1102&DEV_0006&CC_040100
    is tis correct?
