jacobpetrov,
With more info about your PC's hardware I could be more specific, but we'll wing it for now.
- Check my attachment for connections. Make sure you have all three connections exactly as in the diagram. This is critical. NOTE: Each audio connection is numbered. (I added color to the original B&W illustration.)
- There is a Bass Level control on the back of the subwoofer. Set that relatively high for now.
- 20% volume level on the other speakers is a good starting point.
If the above doesn't help we need more info.
- Is this a new product or one that has stopped working properly?
- Did you build this PC?
- Is audio built into the motherboard or separate audio card?
HTH
