3.5mm audio on my U31SD laptop seems broke.
My 3.5mm headphone jack on my Asus U31SD laptop used to work, but does no longer, I've installed fresh windows 7 pro (unrelated to headphone issue really, but I did not notice the headphone issue prior to OS-install) and I have tried multiple drivers.
When I install proper realtek drivers, instead of the generic windows audio drivers, I get the notification that "You just plugged a device into the audio jack.", but the plugged-in device is not reachable anywhere -- not in windows audio control, device manager or realtek HD audio manager. However, my headphones are fine because when I plug them into my USB-mic (which in turn is connected to laptop) I do get proper audio.
It seems pretty obvious that the jack is broke. It's just that it's come as a complete surprise, and it aligned so perfectly with the new OS-install that it annoys me, though I'm sure it's coincidental. Also I can't think of anything that has broke it, a random tug of the cable might have been enough I suppose.
I just thought I'd do a last check here to see if anyone can think of anything else that might be wrong, before I replace the jack, or something..
I'm glad I mess up alot when I'm doing windows/linux multiboot setups because with fresh windows 7, yet again.. the issue was suddenly fixed!
Installed latest realtek drivers and didn't really think anything about it. But wandering eyes noticed the headphones and I started thinking.. and hey, it works.. what a moron I am.
I don't really remember if I did, or did not do this, but my issue may have stemmed from bad drivers which I simply did not remove properly before installing new ones. Just glad I messed up my partitions before I messed with hardware.
Case closed!
