Windows 7: Creative Sound Card Problem Thread
05 May 2009   #91
SirCag
windows 7
Still have problems with my xtreme gamer card.
I installed Windows 7 RC 64 Bit, dont have crackling and stuff..but as soon as i try to open new tab in firefox, or click on link, sometimes even scrool my sound get killed
it does not happen when i surf in IE (but i havent been using IE much, just tried to open and close tabs and scrool the page), but there i get crackling during loading of page.
My system is same as before:
Intel Bad Axe 2
2GB RAM
Windows 7 RC build 7100 64bit
Creative xtreme gamer sound card
etc..
05 May 2009   #92
Archer1978
Genuine Windows 7 SP1 Home Premium 64Bit
Have you guys tried Youp Pax Drviers????
You can get them in the forum of driverheaven.net
05 May 2009   #93
LePoilu
Vista H.P. SP1 x32 Seven RC x64
At this time it seem's that my problem is gone with the RC.
Using WinUpdate Driver for my audigy platinium there's no more cracking & Cie after few listening minutes. Hope it's definitly gone.
05 May 2009   #94
bloke
Windows 7 7600 x64 (16385) Ultimate,Windows Vista x64 Ultimate
i done a fresh install of the rc1 x64 ultimate, used compatibility mode for EVERY program i installed (except any games) vista sp1 and ticked the run as admin box, then right clicked the install.exe for the drivers and chose run as admin as well. i checked to make sure i had the latest drivers of everything and all my issues are gone, 5.1 and in 7.1 modes. i am using 24 bit 48000 in the audio setup in windows and in the asus control panel as some games like CODWaW have an issue with any bitrate higher than that.
all my specs are as is when i installed. so it seems the issue is purely creative, maybe try what i did with compatibility mode?
06 May 2009   #95
Faxe
Windows 7 Beta Build 7000
I switched to the Ultimate 64 Bit Release Candidate, I used the Win 7 Build 7000 32 Bit before but all of my problems seems to be fixed. I use a Audigy 2 ZS, Windows managed the card really fine, no problems with stuttering sounds or something liked that. Now I installed Audigy_SupportPack_2_18_0001_W7 and it blows away, no problems with the sound, the equalizer and eax works well and everything fine, I will test later in the evening, have to go to work. Good luck everyone.
06 May 2009   #96
wrathloki
Well I had popping, crackling and background noise on build 7000 64 bit with my X-Fi Titanium and I'm glad to say that with the new install of RC1 64 bit using the Win7 beta drivers from creative I have no popping or crackling and absolutely 0 background noise at 100% volume.
Windows 7 RC1 x64
Creative X-Fi Titanium
Gigabyte GA-965P-DS3 Motherboard
4 Gigabytes Corsair XMS2 800mhz ram
Stock Overclock Zotac 8800gt
1TB Western Digital 32 Meg Cache HDD
06 May 2009   #97
wrathloki
Quote   Quote: Originally Posted by bloke View Post
You'll probably actually be fine without running everything in compatibility mode.
06 May 2009   #98
wrathloki
Quote   Quote: Originally Posted by SirCag View Post
Intel Bad Axe 2
2GB RAM
etc..
Are you using the win7 beta drivers from creative, did you disable onboard audio, and did you uninstall the basic windows sound drivers from your card before installing the new drivers? I did those 3 things and I'm using RC1 and it's working just fine.
07 May 2009   #99
XGUNTHERC
Windows 7 Ultimate Edition x64
I didn't do ANY of the 3 things the guy above mentioned. I simply installed Win 7.. and when I got to the sound part. I got on Creatives site. found the drivers for my X-Fi XtremeGamer, they are the 2.18.0013 and they installed with no problems, I didn't need compatibility mode or anything. they worked perfect.
Try taking your X-Fi Card out. Restarting the computer without it.. then power it down again. Reinstall the CARD, and then boot. try the creative driver again and see what happens.
I also heard someone was using the XP 64bit driver with there Xfi and it worked. try that after if you'd like.
07 May 2009   #100
SirCag
windows 7
i think i fixed my problem..finaly
i installed new graphic drivers from XFX since and afther that sound stoped only once (when UAC asked if i want to install something and darkened whole screen)
Creative Sound Blaster Audigy FX Sound Card, no playback/recording
Hi, I recently purchased the Creative Sound Blaster Audigy FX and am having problems getting it to actually play any audio or record any sound. I've browsed other threads with similar issues on this board and as such have disabled my motherboards onboard audio in my BIOS settings, have...
Low volume with new sound card(Creative Sound Blast 5.1 VX)
Hello! I got a new sound card today. Installed it, installed the drivers from the CD, plugged in the headphones and it works. But the sound levels are way to low. I raised the volume in all the places I could find, but it's still a bit low. Here's the card: Creative Sound Blaster 5.1 VX...
Creative Sound Blaster Audigy 24bit Sound Card
I installed windows 7 a little while ago but i cant seem to get a driver that will recognize my sound card. the computer doesnt think its installed correctly but when i was using Xp it was just fine. ive tried another PCI slot but no such luck. all of the drivers i have tried tell me that they dont...
Drivers
Creative Sound card
I've got a Creative Sound Blaster X-Fi Xtreme Audio. I have 2/2.1 speakers. What jack in the back of the card should I be in? When I run creative diagnostics I hear the left and right speaker but not my center speaker. With the 2/2.1 speakers do you stay in the green jack?
