Windows 7: Creative Sound Card Problem Thread
15 Mar 2009   #51
thunder2008
Windows 7 RC 7100
Seems like the difference in drivers that microsoft chose to use in W7 are so different from those in Vista that the included compatibility wizard has become quite useful in sending the various error messages back to MS.
It is hoped that the up in coming W7 RC edition will have resolved the audio driver issues that are present in the W7-7000build.
While W7 is slimmed down and faster as a result of trimming the bulk from Vista; there must be a compromise in providing an actual " working " set of audio drivers for the W7 os that are compatible with Vista as Windows 7 has so vaunted up W7 to be.
Other than the audio driver problems with distortion as well as unrecognizable hardware from non-compatible drivers like Asus Creative Cards plus other brands Windows 7 also has issues with Cad programs like Solidworks in that it won't open files from the cad programs interface.
The opening of files is only accomplished from the user file directly. Moreover saving files is also not able to work at all whether a user is running SW08 or SW09 with any service packs, they are all not working properly.
15 Mar 2009   #52
dsopocy
Windows 7 Professional 64-bit
thunder2008 -
Please add my info to your list:
dsopocy......Creative SB X-Fi XtremeMusic (OEM SB0467)....nVidia nForce4 SLIx16
15 Mar 2009   #53
bloke
Windows 7 7600 x64 (16385) Ultimate,Windows Vista x64 Ultimate
there's a list? what list? can i be on the list? what do i have to do to be on the list? hello?
oh the sound issue is with all w7 builds. unfortunate.
15 Mar 2009   #54
LePoilu
Vista H.P. SP1 x32 Seven RC x64
Quote   Quote: Originally Posted by bloke View Post
First post of the topic
16 Mar 2009   #55
thunder2008
Windows 7 RC 7100
Quote   Quote: Originally Posted by dsopocy View Post
thunder2008 -
dsopocy......Creative SB X-Fi Extreme Music (OEM SB0467)....nVidia nForce4 SLIx16
Done
16 Mar 2009   #56
thunder2008
Windows 7 RC 7100
Nice keyboard bloke:)...it's the same as mine.
Noticed from your sig that you have Asus Xonar 1.3 are you having issues with it or ?
Before adding you to list want to first make sure that i'm not listing dis-information?
16 Mar 2009   #57
bloke
Quote   Quote: Originally Posted by thunder2008 View Post
yeh i love this k/b, the only thing i dont like is no embedded numb pad, which i bought a wireless one separate. occasionally i get interference and have to turn the k/b off and back on, but i aint gettin rid of it.
yeh i have certain probs that are very similar to the creative issues, so chins up creative owners, your not on your own.lol i had a xf-i platinum once (its sitting in my cupboard)
check this link out, it explains in detail.
HDAV1.3 (deluxe) windows 7 sound problems
does this mean im on the list?
16 Mar 2009   #58
thunder2008
Windows 7 RC 7100
Yep your added
16 Mar 2009   #59
bloke
i think it could have something to do with the pci or pci-e bus. when i used my onboard sound while i was waiting for my hdav to arrive i had no issues with crackling. i also have no issues with my hdav1.3 when using headphones (2 channel). its hard to pinpoint this issue. some ppl with 2 channel creative cards are having issues, where i only get issues with 5.1 and above? my xf-i platinum was pci which i thought was starting to fail as it was crackling constantly in games under vista x64, maybe there is nothing wrong with it? and my hdav is pci-e which has issues??
16 Mar 2009   #60
dsopocy
G'day Bloke -
See my earlier post on this subject and the posts in the referenced thread. There are two Creative white papers on the subject of crackling and popping (referenced in my earlier posts) which identify issues with PCI bus latency (particularly with nVidia nForce4 motherboards), but both were written pre-Windows 7 and were dealing with the appearance of the problem when the system is under heavy load, particularly with high end games. Now, with Windows 7 the problem, at least for systems with certain (e.g., nForce4) motherboards and more than 3GB RAM, is present under all conditions, even for the system sound at the beginning of Windows startup. The key clue, IMO, is the RAM dependency: limit your RAM to less than 3GB and the problem disappears. Since my system hasn't changed since running Vista Ultimate 64-bit with nary a sound problem, the implication is that there has been some change in Windows memory management that has exposed a fundamental problem with Creative drivers for certain SB card models (mine is an OEM X-Fi XtremeMusic). Since the problem is limited to Creative sound cards, it's much more likely that the problem resolution lies with Creative, not Microsoft or nVidia.
Dale
P.S.
Please click on icon above and add to my reputation if you have found my posts to be helpful.
Creative Sound Blaster Audigy FX Sound Card, no playback/recording
Hi, I recently purchased the Creative Sound Blaster Audigy FX and am having problems getting it to actually play any audio or record any sound. I've browsed other threads with similar issues on this board and as such have disabled my motherboards onboard audio in my BIOS settings, have...
Low volume with new sound card(Creative Sound Blast 5.1 VX)
Hello! I got a new sound card today. Installed it, installed the drivers from the CD, plugged in the headphones and it works. But the sound levels are way to low. I raised the volume in all the places I could find, but it's still a bit low. Here's the card: Creative Sound Blaster 5.1 VX...
Creative Sound Blaster Audigy 24bit Sound Card
I installed windows 7 a little while ago but i cant seem to get a driver that will recognize my sound card. the computer doesnt think its installed correctly but when i was using Xp it was just fine. ive tried another PCI slot but no such luck. all of the drivers i have tried tell me that they dont...
Drivers
Creative Sound card
I've got a Creative Sound Blaster X-Fi Xtreme Audio. I have 2/2.1 speakers. What jack in the back of the card should I be in? When I run creative diagnostics I hear the left and right speaker but not my center speaker. With the 2/2.1 speakers do you stay in the green jack?
