Windows 7: Creative Sound Card Problem Thread
25 Apr 2009   #71
Bean
XP service pack 3 & Windows 7068 64-Bit
Im running a Creative XFI sound blaster inbuilt on my MSI P6N diamond mobo, and it tends to recognise that my audio jacks are there and on volume control it shows that its playing sound however it normally takes about 5 mins after start up before the sound comes out of my speakers, at first i tried disabling the other audio jacks (front headphone and digital/optical outout) and that worked fine, but now it has gone back to like it was before...
any help please?
BEAN
25 Apr 2009   #72
oenone
vista ultimate 32bit
please advise on what i should do, i cant seem to install my drivers from my cd installer for creative audigy value soundcard, whenever i try to install it i get BSOD.
anyway i have:
windows 7 32bit build 7100
gigabyte MA790GP-UD4H mobo
AMD x2 6200+ black edition
ati 4870
4GB Ram
25 Apr 2009   #73
bloke
Windows 7 7600 x64 (16385) Ultimate,Windows Vista x64 Ultimate
Quote   Quote: Originally Posted by oenone View Post
anyway i have:
ati 4870
4GB Ram
Have you tried downloading the latest drivers from their website? most of the time when you buy something they will only include the initial release (first release) driver for that product and there are usually updates by the time you buy the product from when it was packaged and the driver cd was created. if there is not any driver updates, try booting into safe mode (F8) whilst the system is proceeding in post startup and then locate the latest driver (either on your cd or where ever you may have downloaded the newer driver to) and try running it then.
my graphics drivers for some reason can only be installed in safe mode, if i try it normally i get the same error as you, bsod during install. though it never happened with beta 7000?
hope that helps.
25 Apr 2009   #74
oenone
@bloke
will try it now sir
will post here on what happens
25 Apr 2009   #75
bloke
please dont call me sir, either bloke or rick. lol i am of no high intelligence nor rank here. merely a scout just trying to help a brother.
26 Apr 2009   #76
sphami
Windows 7 64-bit build 7600.16385.0907123
[quote=thunder2008;28386]I thought about what would make it easier for creative to actually get around to fixing what is wrong with the drivers for not just my card but all of the brand manufacturers cards which are creative products.
And, to be able to have all of these Creative cards in a single format that will allow them to see which cards are still having an issue with Windows 7.
Please list your card details completely including your motherboard.
1.thunder2008................Asus SupremeFx X-FI.................Asus Rampage Extreme
2.greenberet951.............Creative Deluxe Audigy 2zs..........Asus A8N
3.wrathloki....................Creative X-Fi Titanium.................Gigabyte GA-965P'DS3
4.imacken.....................SB Audigy.................................Gigabyte GA-P35C-DS3R
5.Darrenew...................Sound Blaster live 24bit...............Dell Dimension 5100
6.mdw1166...................Creative SB X-Fi Platinum.............Gigabyte GA-8KN-Ultra 9
7.LePoilu......................Creative Audigy Platinium..............Gigabyte EP45-DS3L
8.bobalobabingbong.......Creative SB X-Fi XtremeGamer.......Nvidia nForce 680i SLI
9.greyeyezz.................Creative SB Audigy 2ZS ...............Asus K8V-X
10.boxterduke..............Creative SB Audigy 2ZS................Asus P5K
11.dchristey................Creative SB X-Fi Xtreme................Gigabyte EP35-DS4
12.DukeX007X.............Creative SB Audigy 2ZS Gamer........Gigabyte GA-K8NXP-SLI
13.Stabgotham............Creative X-Fi XtremeMusic.............MSI K9A2 Platinum
14.Hellfight..................Creative Audigy 2 ZS....................Asus A8N SLI Premium
15.dsopocy.................Creative SB X-Fi Extreme.Music.......nVidia nForce4 SLIx16
16.Bloke.....................Asus HDAV1.3 Deluxe....................XFX 790i Ultra
17.yannis18................Creative Audigy 2.........................Abit IC35Pro
18.dchapin..................Creative X-Fi Platinum..................motherboard not listed
19.Winrar...................Creative SB Audigy 24-Bit..............Foxconn
20.Bean.....................Creative SB.................................MSI P6N Diamond nForce 680i
21.oenone..................Creative Audigy...........................Gigabyte MA790GP-UD4H
22.Sphami...................Creative X-Fi Platinum.................EVGA 790i Ultra
23.
24
26 Apr 2009   #77
bloke
i dont think its to do with creative or asus, more so microsoft and a driver or 5.1/7.1 support in win7.
is it still crackling in the rc1 7100 build?
26 Apr 2009   #78
sphami
sound crackling
I took my card out with build 7077. I will put it back in tomorrow moring and try it out. I am hoping it works, surround sound here I come ? ? ?
I lit out from Reno, was trailed by 20 hounds
26 Apr 2009   #79
george360
vista
george360 ASUS P5Q-Deluxe BIOS 0704 Creative Sound Blaster Live Value
I have tried 7057, 7068, 7077 and 7100. only the 7057 allow me to update the creative driver by without a blue screen.
26 Apr 2009   #80
winrar
Seven 7100 - Mac Osx for iPC - Xp too - of course!!
23.WINRAR..................Creative SB X-Fi Xtreme Fidelity .....foxconn 45 MX-C
24
Creative Sound Blaster Audigy FX Sound Card, no playback/recording
Hi, I recently purchased the Creative Sound Blaster Audigy FX and am having problems getting it to actually play any audio or record any sound. I've browsed other threads with similar issues on this board and as such have disabled my motherboards onboard audio in my BIOS settings, have...
Low volume with new sound card(Creative Sound Blast 5.1 VX)
Hello! I got a new sound card today. Installed it, installed the drivers from the CD, plugged in the headphones and it works. But the sound levels are way to low. I raised the volume in all the places I could find, but it's still a bit low. Here's the card: Creative Sound Blaster 5.1 VX...
Creative Sound Blaster Audigy 24bit Sound Card
I installed windows 7 a little while ago but i cant seem to get a driver that will recognize my sound card. the computer doesnt think its installed correctly but when i was using Xp it was just fine. ive tried another PCI slot but no such luck. all of the drivers i have tried tell me that they dont...
Drivers
Creative Sound card
I've got a Creative Sound Blaster X-Fi Xtreme Audio. I have 2/2.1 speakers. What jack in the back of the card should I be in? When I run creative diagnostics I hear the left and right speaker but not my center speaker. With the 2/2.1 speakers do you stay in the green jack?
