#121
Thanks for the suggestion, bloke.
I'll have to try that eventually, the problem is I also can't seem to get system image to work (I have a dual boot with XP on separate drives, but apparently some files for W7 are on the XP drive, so it will only let me create an 80GB image of both drives and I don't have enough space).
So if I start trying these things and they don't work I'm back to formatting, and with everything else working and all my programs (office, CS4, etc) installed and running, I'm reluctant to go through it all again.
I did figure out a temporary solution, though: install the driver and listen to music while I work, then uninstall before restarting. It's a pain, but it works.
