Creative Sound Card Problem Thread
Page 15 of 16 FirstFirst ... 513141516 LastLast
  1. Posts : 14
    Windows 7 64-Bit
       #141
    Creative driver does not work for me either.
    I have Creative SB X-Fi elite Pro, on EVGA X58 3SLI motherboard. And I have WIN 7 64-bit.
    Peyman
  2. Posts : 4,517
    Creatives official drivers work fine for me even using THX console.
    how i done it:
    put in the X-FI Cd (Vista Version)
    Run setup w/compatability mode for vista:
    Custom Install
    Install ONLY THX Console and Volume Panel
    Reboot when done
    Download latest console manager and driver from creative.
    Install Console manager .. do not reboot
    Install Driver --> reboot
    And thats it .. everything will work flawlessly (at least for the Xtreme Gamer)
  3. Posts : 4
    win 7 & xp
       #143
    creative sound card line problem
    i have this Creative Sound Blaster 5.1 Sound Card - High-quality surround audio & i download that driver from here Creative Worldwide Support Creative Worldwide Support for win 7. its works great in win 7 but line in doesn't work in win 7. i have local made tvtuner card. to listen sound form tv tuner i need to enter the sound input to my sound card. that means one in the tv tuner out put & another in sound card input. the prob is the mute function does not work i cant mute line in, line in is always on. i use windvr to watch tv show. if i listen a song in pc i close windvr i cant mute it.but the same things work fine in xp. how do i mute line in ? plz help or suggest me a sound card that i mute linein in win 7 & also it should work in win xp. sorry for my bad english.
    twitter.com/pinakel
  4. Posts : 5
    Windows 7 x64 Ultimate
       #144
    I was updating my drivers recently and i used driver cleaner to remove all traces of the previous driver, which i probably shouldn't have done because now i can't install them at all.
    There's a yellow exclamation in device manager, i have tried uninstalling the sound card and rebooting, but that doesn't help. If i try to search for the driver manually it tells me there is no driver available.
    Does anyone have a solution to this problem?
    The sound card i'm using is the Creative X-Fi Xtreme Music which has been working fine since i bought 7 on release.
    Any help is much appreciated, thanks.
  5. Posts : 6,879
    Win 7 Ultimate x64
       #145
    Guybrush, welcome to the forums.
    If you haven't yet try to manually install the driver,
    Creative Sound Cards.
  6. Posts : 5
       #146
    https://www.sevenforums.com/sound-audio/21804-creative-sound-cards.html#post303346
    Thanks for your reply.
    I tried that as well, but i'll give it a try again as i don't think i was doing it right.
  7. Posts : 3
    windows 7 home premium
       #147
    creative X-treem gamer . MB asus M2N4-sli , same thing crappy sound
  8. Posts : 5
       #148
    I tried it again, but unfortunately it didn't work.
    It keeps telling me it cannot load the creative driver.
    I'm not sure what else to do apart from formatting my HD, but that's a bit drastic.
  9. Posts : 6,879
    Win 7 Ultimate x64
       #149
    Unfortunately things like this,
    have a habit of happening occasionally when you do things like this,
    Even more so if it was the free version of Driver Cleaner as it hasn't been updated in 3-4 years.
    Only other way around it is if a system restore can bring it back to where it was before doing the "cleaning". That or if you happened to create a backup image of the system that you could reload.
  10. Posts : 2
    Windows 7 Professional x64
       #150
    Slightly different problem
    I've had my X-Fi Fatal1ty for a number of years now (4 years I think?) and until a few months ago it was fine barring the odd minor issue. Recently I've started having random BSODs - not heat/stress related, often in games but also randomly in Windows, sometimes very shortly after booting. Even viewer just gives the generic 'Kernel Power' error which basically means 'your computer crashed'.
    What makes me think the sound card is the cause is that often the first sign I'm about to crash is the sound - often it stops completely, but sometimes it screeches and other times (more frequent recently) my headphones will only give me the right channel and then nothing at all but if I unplug them from my X-Fi Fatal1ty's front drive bay my speakers start up playing in 5.1 just fine - momentarily... Then I get a BSOD some moments later.
    Other times though, the first sign something is awry is my wireless network card (also in a PCI slot) drops and won't come back til I reboot. I thought it was my motherboard's PCI slots dying but I've done some testing with tonnes of drivers including both daniel_k drivers and several version of the Creative drivers including the 5 year old ones off the CD but I still get the BSODs. Tried enabling/disabling onboard sound in BIOS, no change. I uninstalled the Creative drivers completely and forgot to reboot and this time instead of a BSOD, my sound kept playing but the graphics card crashed, as well as my G15 keyboard being unresponsive showing no fluctuations in CPU usage (a sure sign the PC has frozen up).
    I rebooted and since then, I've been using the onboard sound which plays my mp3s in *shudder* stereo and not a single crash or BSOD of any kind.
    Conclusion: There was some sort of update applied a while back that probably coincided with when I updated to the latest Creative drivers causing me to think that was the cause (a system restore temporarily fixed the issue but it eventually came back). Whatever this update is, affects the motherboard's PCI bus (and probably the PCI-E bus too), causing data corruption between the 2 devices on the same bus.
    I've bought a new motherboard to test if this is motherboard related or sound card related but I haven't got around to the mammoth task of gutting my PC to swap mobos. My gut feel is that it's the sound card's drivers causing this corruption, leading to a BSOD since it seems to have stopped once the drivers are uninstalled. It would also explain a LOT of the previous issues people have experienced.
