Razer Electra Static Noise
  1. Posts : 83
    Windows 7 Ultimate 64bit
    Well,hello ! Just like thet title says,I got a new headset yesterday,and it was amaizing,but suddenly,a weird static noise just appeard,and I don't know how to get a rid of it.
    Any help would be amaizing !
  2. Posts : 2,409
    Windows 7 Professional 32-bit/Windows 8 64-bit/Win7 Pro64-bit
    Could you try using a different headset or speakers?
  3. Posts : 83
    Well,I could borrow my sister's speakers,due to the fact that she has the same speakers as me
  4. Posts : 2,409
    Try using it and hear if it makes the static noise also. If it does, first try running any antivirus. If it detects any malware, let the antivirus heal it. But if it cannot be healed, try removing it. But if you do need to remove it, tell me the file path and malware name first. If no viruses get scanned, it could be either a problem with a driver or the sound card itself. Could you find the model of your sound card and tell me it so i can find the website with the driver you need? Read this Driver Install - Device Manager if you need to get a new driver. Also, if updating your driver does not work, your only choice is to get a new sound card.
