Sound on desktop stopped working; see repair attempts
  1. Posts : 21,004
    HAVOC said:
    The OP said they are using onboard sound.
    Yep I know but what onboard as the specs list two??
    Attached Thumbnails Attached Thumbnails Sound on desktop stopped working; see repair attempts-audio2.png
  2. Posts : 21,004
       #12
    Have just searched and there is no drivers available for the Realtek as itis the audio listed for that mother board https://www.asus.com/Motherboards/P5BVM_SE/#specifications
    My suggestion would be to ge a sound card not expensive and far betterquality sound in my view anyway.
    I use Asus Xonar DG cards in all my machines and the sound is perfect
    http://www.newegg.com/Product/Product.aspx?Item=N82E16829132020
  3. Posts : 1,442
    Windows 7 Professional 64bit
    I looked at info about that MB and can't find why two are listed. Maybe the OP had a sound card and removed it?
  4. Posts : 21,004
       #14
    Yes mate my point too I think at some stage there has been a card but do AMD do a sound card?? What I think might be the case is perhaps a GPU with audio perhaps??
    What is AMD High Definition Audio Device? [Solved] - Sound Cards - Components#.
  5. Posts : 1,442
       #15
    I believe some video cards have a SPDIF connector on them so you can have audio through your DVI or HDMI cable.
    I could be wrong though.
  6. Posts : 21,004
       #16
    HAVOC said:
    I believe some video cards have a SPDIF connector on them so you can have audio through your DVI cable.
    No mate the DVI is graphical stuff only for that you would need an HDMI hook up and I think there was mention about a HDMI via an optical port but in all honesty why bother when the quality is there from the normal jacks. The GUI is just perfect for me for effects and mixing etc
    Xonar DG - Sound Cards and Digital-to-Analog Converters - ASUS
  7. Posts : 1,442
       #17
    If you look at this thread you'll see that the computer shows AMD audio and Realtek audio if a certain option in the BIOS is selected.
    AMD and Realtek Sound Options - Asus - Motherboards
    And from AMD's own website on the Radeon HD 6570:
    Integrated HD audio controller
    • Output protected high bit rate 7.1 channel surround sound over HDMI or DisplayPort with no additional cables required
    • Supports AC-3, AAC, Dolby TrueHD and DTS Master Audio formats
  8. Posts : 8
       #18
    Hey everyone,
    Busy weekend. Sorry for not getting back. I have never had a sound card installed on this motherboard. I did disconnect my Hd and connected another perfectly fine working one from a different computer and I still have no sound.
    Therefore, should I ASSume that the onboard sound is just messed up and getting a separate sound card would do the trick?
    Thanks for all of your help and patience everyone.
    ~Shari
  9. Posts : 21,004
       #19
    Yep that is what I wold do Shari inexpensive and much better quality sound too.:)
    ASUS Xonar DG 5.1 Channels 24-bit 96KHz PCI Interface Sound Card - Newegg.com is the one I use good effects and mixer if you like mucking around with sound:)
  10. Posts : 8
       #20
    ICit2lol, I ordered the sound card. Will let you know if all works when I get it and get it installed.
    Thanx so much, everyone.
