Audio from speakers, not from headset, vice-versa.
  1. sd0
    I have 2 speakers, nothing fancy. And a Sennheiser USB headset. Problem is when I set my default audio device to Realtek High Def Audio, my speakers work and my headphones don't. I have to manually set the default device to my headphones, but then my speakers don't work.
    Is there a way to have audio through both?
  2. Posts : 28,845
    Win 8 Release candidate 8400
    sd0
    could you give us info on your sound card/chipset so we can go reseach it for you.
    thanks
    ken
  3. sd0
    I'm using onboard sound on my ABIT IP35 Pro.
  4. sd0
    Hate to bump, but can anyone help me with this?
  5. Posts : 6,879
    Win 7 Ultimate x64
    Unless the program has the option of using an audio device other than the Windows default (and a USB headset is a second audio device with its own driver, and fucntions completely independent of whatever other sound card is installed), then what you are looking to do isn't going to happen.
