Difference between Realtek HD Audio Manager & Realtek HD Audio Driver
  1. Posts : 72
    Windows 7 Ultimate 6.1 x84
    It's been a year since I migrated from Windows XP to Windows 7 which I downloaded Realtek HD Audio Manager R2.70 and audio has been working fine except the only issue it didn't come with 'Stereo Mix' preventing capability to record sound direct from the soundcard. It took me 14 months to restore Stereo Mix as each time I was told to update audio drivers I would update HD Audio Manager so what is the difference between these two Realtek ?
    I installed Realtek HD Audio Driver R2.72 last night and it restored Stereo Mix which now enables me to record system sound whilst using screen recorders.
  2. Posts : 220
    Windows 7 Ultimate
    Realtek HD Audio Manager is a software driver used on Windows computers. It handles recording and playback of audio programs. It is required for many audio programs to operate.
    While Realtek HD Audio Drivers is a tool that allows you to listen to audio in HD on your PC.
    Stereo Mix is used to transfer audio that the PC is playing to recording software such as Audacity, so that you can record what you’re hearing.
    When one upgrade their OS like in your case from XP to Win7 with the same motherboard and sound card it is always advised & recommended to download the latest soundcard driver, because the only thing that had changed was the operating system.
    The advice is not to go to windows for it, but to go to the motherboard manufacturer, because it would be specialised for the system rather than a generic driver, which might not be as good, or even cause problems.
  3. Posts : 21
    8.1
    bad advice. use the one from realtek, it will always be newer.
