Issue when changing to speakers from headset sound
  1. Posts : 5
    Windows 10 Pro 64bit
    It's kind of hard to explain but when i disable my headset sound to enable my speakers the volume on google chrome stops working until i re-enable my headset all other sounds on my computer work in both headset and speakers except for in chrome with the speakers, this issue was not an issue until today and i have been using the same method to enable my speakers everytime.
    Hope someone here has had this issue or can help me fix it, below will be a screenshot of where i disable/enable my speakers/headset usually
    Screenshot by Lightshot
    As everything except Chrome appears to work OK, it would lean towards a Chrome problem rather than an "audio" problem.
    By the way, here is how to post screenshots on this forum
  3. Posts : 5
    Ah true sorry, i just figured out that chrome only uses 2 of my 5 speakers and both those speakers seem to be broken, sorry for wasting your time!
  4. Posts : 8,135
    Not a problem. The issue is resolved.
