How to toggle between default sound device using AutoHotKey
Edit: See second post. Found script for AutoHotKey but not sure how to compile or use it ? Also when ever I plug a USB device in it changes default sound device from Line 1 to SRS.. I usually plug my Smartphone on for charge every day using USB so it gets annoying.
I'm using two audio enhancement plug-ins SRS Audio Sandbox & Breakaway Audio Enhancer. SRS uses Realtek HD Audio Output while breakaway uses SRS Audio Sandbox and when I load my computer for the first time SRS automatically sets SRS Audio Sandbox (WDM) as the default sound device meaning each time I have to open playback devices and change the default sound device back to Line 1 (Breakaway Pipeline) in order for the sound to work.
There seems to be no way to disable SRS from changing the sound device when it starts/loads for the first time so is their a way I can a hotkey shortcut key to simply change default sound device to Line 1 ?
Audio Device: Breakaway
Input > Breakaway Pipeline 1
Output > SRS Audio Sandbox
Audio Device: SRS Audio Sandbox
Input > SAS is the default sound card
Output > Realtek HD Audio Output
