#41
C-Media 8788 soundcards work fine too with the latest Windows 7 drivers from Auzentech (X-Meridian).
Works with beta driver for Windows 7 64 bit. PowerDVD does not work with this driver.
Nvidia 8800GTX 768MB PCI-E works fine on my setup.
Regards
UKMedia
The Auzentech Xploion 7.1 Dts connect works can that be added to the list and there's also a win7 driver over at there website i can confirm it works in x64 also
Creative Labs X-Fi Elite and SB Audigy 2 Platinum Professional both work w/ updated drivers from website. You might as well throw the included driver cd's in the garbage. (Although they DO make great coffee cup coasters for my desk!)
Sound Blaster X-Fi Xtreme Audio works with default drivers.
IDT Audio 92xx
Intel 945x motherboards
Works - With tweaking ...
I can't test the optical output, only the analog, 5.1. I've had a great experience with using the Windows 7 64 drivers from Asus for the P5Q PRO Turbo motherboard onboard sound VIA VT1708S.
The file i downloaded is named VIA_Audio_V6017100_Windows7.zip Windows 7 ids it as 6.0.1.7100 dated 5/8/2009 from VIA Technologies, Inc.
I've tested the sound in MS Flight Simulator X, Caesar IV, and The Sims 3 as well as music in iTunes. I was a little concerned when I bought the board that it had VIA onboard sound rather than Realtek, but I am very pleased with the VIA onboard sound. At least on the analog side the drivers definitely work.
