Suggestions for cubase 7 professional sound card for Asus z87pro mobo
  1. Posts : 74
    windows 7
    Hi Chaps
    I am looking for any suggestions for a professional soundcard for my new motherboard which is an asus z87pro. I was up until recently using an m-audio 1010lt audiocard with multiple ins and outs which i used with cubase 7. Since this card no longer fits i am looking for any alternatives which offer as much flexibility. All suggestions welcome.
  2. Posts : 124
    Windows 7 Ultimate x64, Windows 8.1 Pro x64 (on laptop)
    what kind of price range?
    This is £90 but it seems highly rated by producers online :) http://www.amazon.co.uk/ASUS-Xonar-D.../dp/B0011BC1FO
  3. Posts : 8,135
    I have a recording studio (I have Sonar X3 and ProTools MP9). Most do not recommend PC sound cards for recording. You are better off with a USB connected recording interface device. There are several in the under $200 US category including Focusrite (a UK company). The Focusrite Scarlett 2i2 is a popular two channel unit, that will accommodate either instrument or microphones and provide outputs for speakers or headphones.
    Home | Focusrite
  4. Posts : 74
    windows 7
    This is £90 but it seems highly rated by producers online :) ASUS Xonar D2X/XDT - Sound card - 118 dB SNR - 7.1 - PCI Express x1 [PC]: Amazon.co.uk: Computers & Accessories
    Hi there I'm looking to spend around £200 for something with a similar number of ins and outs and midi/sp/dif connectivity, as i have a growing collection of synths and guitars. I've been looking at the M-Audio Avid Fast Track Ultra which could fit the bill costing £200+ duties.
  5. Posts : 8,135
    As I mentioned a USB connected device. One of my audio interface units is an MAudio Fastrack Ultra 8R (8 analog inputs).
    I also have a Roland Octa-Capture (8 channels) which is my primary recording interface unit. They make smaller 2 and 4 channel units. I like the Octa-Capture as it has built in limiters that you can use (optional) when recording.
  6. Posts : 74
    windows 7
    Hi Fireberd,
    Indeed, it is the MAudio Fastrack Ultra 8R version that I am quite keen on. yesterday i spent a few hours researching the user reviews. On the whole they seem very positive and i am inclined to wait for a used one to appear on Ebay. I also like the idea that it will just slot into my rack to save studio space. Can i ask if you have encountered any issues with yours?
    AS for the Roland Octa-Capture, I shall check out what other users say their experience is.
  7. Posts : 8,135
    My Fastrack Ultra 8R is my backup unit. It rarely gets used. The Roland Octa-Capture is my primary recording unit.
    The guru of music electronics, Craig Anderton has a review of the Octa-Capture on the harmony central site.
    Roland Octa-Capture Interface - Now with Conclusio... - Harmony Central
  8. Posts : 74
    windows 7
    I've settled on theMAudio Fastrack Ultra 8R in the end, it should arrive from Ebay(USA) in about two weeks.
    Thanks for your recommendation. One final question: have you encountered any issues with yours during your time with it?
    best
