Sound breaking up
Page 2 of 2 FirstFirst 12
  1. Posts : 135
    Windows 7 64bit
    well my pc is using 2.55gb ( i have NO idea why ) out of my 4gb total.
    Skype is using 175k , Idle( not using it ) ...
    Chrome from 113k to 160k , 4 processes that are that level .. the rest are smaller
    I was planning on getting 4 more gigs of ram .. you think that might be the problem ?
  2. Posts : 1,449
    Windows 7 ultimate 64-bit
       #12
    Simply put; yes!. because as i mentioned before; if your system does not have enough free ram to support several open tabs or windows at once; it will in fact cause applications like youtube that use audio and video to studder or react very slowly and poorly. I know this for a fact because i have experienced this myself on more than one occasion as a on-demand computer repair tech.
  3. Posts : 135
    Windows 7 64bit
    well then ill put get Ram on my to - do list on a higher priority level since i cant listen to music while i work properly and its really irritating. If anyone has any other suggestion please do share
    Is everything okay with the current running flash ? should one of them be disabled ? i have heard only one instance of flash should be running
  4. Posts : 1
    WIndows 7
       #14
    I bet it's not the ram
    I have 8GB of ram and I'm using like 3-4GB Max (ALWAYS) and I have exactly the same problem, it's not just with chrome, even if media player is playing something the sound breaks if I click around or do whatever... even when something is loading same thing. I re-installed the drivers but no luck. This is TOO annoying considering the fact that I play music on my computer and recording stuff. :/ If anyone knows the solution please help
  5. Posts : 1
    Audio Keeps breaking up
    I just purchased a new HP Probook 450 G2
    When I listen to the media player or online music the audio keeps breaking up as if there is electricity going through.
