Sound Randomly stops
Page 2 of 2 FirstFirst 12
  1. Posts : 21,004
    venkateshr said:
    stilli1988 said:
    so it seems it was my hdd. which is only a few weeks old hopefully it was some type of glitch or corrupted files or something from doing a large amount of copying to it. I wiped the drive and copied everything back from my backup drive and haven't had a problem yet. thx for your help guys.
    Hi bud, I am experiencing the same issue here. Sound stops randomly in xonar stx. It only works after a restart. Was our issue fixed or did it come back? I was using Win 7, wiped that out and installed Win 8.1, still have the same issues. Installed uni xonar drivers, no change. I do not see how wiping the HDD completely fixed the issue. Did that really fix it? Should I try that too?
    Hello venkateshr mate it is better you post your own thread - I know it is very tempting to ask when you see a very similar problem but having two individuals posting their issues in the same thread leads to confusion and inevitably distracting those of us who are attempting to answer the query.
    Now again if you are running 8 then you should be posting in that forum - it is the same crew as here in 7 and is specific to 8 problems. You just need to sign up just as you did for this forum:)
  2. Posts : 1
    I'm just started having this issue too. Only thing that's changed recently was installed Kaspersky and a game from steam a couple days ago. Was working just fine until today and I started having the sane issue.
