Missing 'equalizer' in Realtek HD audio manager
  1. Posts : 2
    As the title says, I have no equalizer even thought I'm using the latest version of the driver. I did a lot of research but couldn't find a way to fix it :/
  2. Posts : 14,606
    check this thread and see if it helps,
    Missing Equalizer in Windows 7 Enhancements Tab
  3. Posts : 2
    I've deleted everything that could possibly have something to do with audio but still no effect ;/
    I think there may be 2 things causing this. The first think could be the basic windows' audio driver that automatically is installed after I reboot system after deleting realtek drivers ( I reinstalled different versions couple of times) and the only way to stop it is How to stop Windows 7 automatically installing drivers but unfortunately I'm using windows home premium version :/
    The second thing could be the dolby home theatr thingy but it comes with the realtek driver so I doubt that.
    e: I found this http://gpsearch.azurewebsites.net/#174 but dunno what to do with it, I can't find this thing in regedit
  4. Posts : 1,992
    10 Pro x64
    i noticed you have a y580 in that case are you using the package made by lenovo for that very machine? you will want to install this one Realtek Audio Driver for Microsoft Windows 7 (32-bit, 64-bit) - IdeaPad Y480, Y580 let windows put in the built in ones then reboot then install that then reboot again.
    best of luck
    rvcjew
