Accidental Removal of Sound Device
  1. Posts : 2
    Windows 7 64
    I purchased a Soundfreaq Sound Platform (SFQ-01) and connected it to my HP Pavilion p7 using Windows 7 via Bluetooth.
    A Sound Platform icon was now in the Hardware & Sound - Devices & Printers window. Because I have multiple devices hooked up via bluetooth to the sound platform I would have to manually connect and disconnect each.
    Now the problem -- I accidentally deleted the Sound Platform icon, and can't for the life of me find any way to connect to it via my pc without it.
    I understand I could use a restore point, but in this scenario it is not an option.
    Also once a device has been connected via bluetooth my pc will not find it again when I try to sync it again.
    Please help!!!
  2. Posts : 2,047
    Windows 7 Home Premium 64-BIT
    Why using a restore point isn't your option for now? Try plugging your Sound Platform to your PC then see if that program will come up again
  3. Posts : 2
    Windows 7 64
    Good idea i'll try that.
    Regarding the restore point: this happened some time ago and I almost gave up, but in the mean time I organized a massive amount of media which I cannot risk loosing...
  4. Posts : 1,449
    Windows 7 ultimate 64-bit
    I am wondering also why cant you use system restore to restore the computer?
    EDIT: now i see why you say not that u cant but that you dont want to. But still, at this point the system restore is probably one of the better routes to go with this issue.
