Ripping Audio from DVD
  1. Posts : 9,600
    Win 7 Ultimate 64 bit
    Is it possible to rip audio directly from a DVD? I received a CD/DVD set of music for Christmas. The DVD has several songs that are missing from the CD and I would like to be able to listen to them other than on my TV.
  2. Posts : 7,379
    Windows 7 ultimate x64
    Hey,
    You can try this.
    Hope it helps.
  3. Posts : 9,600
    Well, bless your heart (and all your other internal organs)! That looks like it may do the trick. I've printed it out and, after I've recovered from the holidays and dealt with a few other things, I'll give it a try. I already have VLC on my machine.
    Thanks!
  4. Posts : 7,055
    Windows 7 Home Premium 32 bit
    13 Awesome (and Free) Tools to Rip Audio From Video ( Some of the software may be outdated)
  5. Posts : 7,379
    Glad it was able to help you
  6. Posts : 1
    Windows 7 Flagship x32
    Freemake Video Convert also works quite well, it can convert DVD to audio format. But if your DVD is commercial with protection, you are out of luck with this software. But you can try other ripper like DVDFab or Leawo DVD Ripper. They all can rip DVD to lossless or lossy format. Protection and region code can be decrypted with them. You should keep the DVD audio for your own use, don't share them.
  7. Posts : 9,600
    I got a chance to fool around with it last night and, after a few failed attempts, I was able to get a copy of the entire DVD's audio ripped to a single track. Supposedly, one can rip individual chapters to their own tracks but darned if I could get it to work that way. I might try some of the other ones Jumanji suggested later to see if I can get individual tracks since most are duplicates of the ones on the CD that came with the DVD but, for now, I have a usable copy (now that Christmas is over, of course).
  8. Posts : 9,600
    lee1123 said:
    ...You should keep the DVD audio for your own use, don't share them.
    You're preaching to the choir. I have issues with DRM but I feel even more strongly against piracy.
