All system sounds are the same
  1. pjd
    Win 7 Professional 64bit
    No matter what sound scheme I choose all system sounds are a low frequency click.
    If I open a wav file and select play from the context menu I hear what I would expect, but when I apply that wav file (e.g. a chiming bell) to say System beep - all I hear is the click!
    Other programs - like my PIM can use the same wav files and produce the expected sound - its only Windows that is stuck on this barely audible click for everything.
  2. Posts : 4,161
    Windows 7 Pro-x64
    Perhaps imageres.dll is corrupt. Try running SFC /scannow from an elevated command prompt and check the console for messages.
  3. pjd
    SFC found nothing - but I found part of the problem - I had system sounds set off in Volume Control mixer (slider all the way to the bottom)
    So... back to the actual problem
    Had to buy a new keyboard in a hurry - the old one decide the Alt keys were sleep buttons Silly me said - okay, so lets get a wireless one.
    The wireless one doesn't have any LEDs so I went to Control Panel\Ease of Access\Ease of Access Center\Make the keyboard easier to use and ticked the Turn on Toggle Keys boxes - and all I get is this barely audible tone.
    So the real question is - can I change the 'tone' that's played when I press Caps, Num or Scroll Lock, to something I can hear above ambient noise ?
    pjd
    Attached Thumbnails Attached Thumbnails All system sounds are the same-capture.jpg
  4. pjd
    Found a gadget called Toggler that allows me to set sound, also displays indicators in tray
    It'll do
    pjd
