Headphone problem
  1. Posts : 5
    Windows 7 Ultimate 32-bit
    Headphone problem
    Im new to the forums ... looked through a lot of threads for info on my problem. Cant find anything to help me.
    I have problem with my headphones.
    They are plugged in blue jack,speakers in green and mic in red.
    But Realtek HD audio manager cant rekonize ONLY headphone.
    Mic and speakers works fine.So,he rekonize when device is plugged but he doesnt ask me are that headphone like on Win XP.
    And yes,blue jack is ok,cuz he works on Windows XP SP2.
  2. Posts : 4,280
    Do you have your front panel jacks plugged in and working? If so then you should use the green audio out plug. If not. on my sound card blue is for audio in. and I know you stated that it worked in XP but that doesn't mean it will work on 7.
  3. Posts : 5
    No,i have just back panel jacks.
    And i tryed to mix ( to put speakers into blue jack) and i dont get sound then.
    First,i have thought that blue jack is out of order but on XP hes working just fine.
    Check this.
  4. Posts : 6,879
    Win 7 Ultimate x64
    Set to 4.1 or 5.1 instead of stereo in the Realtek controls, that will at least enable you to use both the headphones and the speakers at the same time. Then if all you want to use is the headphones you can turn the speakers off (I assume they have a power button on them). You may need to use the speaker fill option to get sound out of both, at least for any sources that aren't multi-channel to begin with (music, Youtube, etc).
  5. Posts : 5
    @stormy13
    No,its not working.
    I set tu Quadrophonic and then i hear on headphones but that is not what i want;hear only sound who is in a back of the song or a movie.And when turnthe speakers off ,there is no difference.
    It very wired i know...but,maybe is something wrong with drivers?!
    Has any1 problem like this?
  6. Posts : 6,879
    Win 7 Ultimate x64
    Can't help with what settings to look for but I used to do just what I suggested previously with headphones and speakers using an Audigy. To do it I did the following,
    1. Headphones in the fronnt out jack (green) and the speakers in the rear out (black, not sure which it is on the Realtek)
    2. set it to 4.1/5.1 in the speaker settings
    3. enable CMSS (same as speaker fill on the Realtek) and then use the fade slider (front-rear) to force the sound to one or the other, depending on which I wanted to use.
    Doing 3# allowed for full sound out of either the speakers or the headphones. Like I said can't help with the settings as I haven't used RealTek in a very long time, so no idea if the options like I outlined are there or not.
  7. Posts : 6
    windows 7 professional 64 bit
    hey guys,
    I just upgraded from 32bit vista to 64bit win 7.
    Motherboard is Asus P5N32-E SLI
    Soundcard came with mobo: SupremeFX Audio Card
    ADI 1988B 8 -Channel High Definition Audio CODE.
    My front panel headphone jack has not survived the upgrade.
    It was working fine before.
    Now in control panel > Manage Audio Devices the headphones are 'not plugged in'
    Can anyone help?
    Thanks.
  8. Posts : 5
    shimmy river said:
    hey guys,
    Can anyone help?
    Thanks.
    Same problem....
    Just i upgrated from XP to Win 7
  9. Posts : 6
    I just installed the vista 64 bit audio drivers for my mobo....now my front panel headphones work again
