Can't get sound to work on both PC & TV (SB0730)
Page 2 of 2 FirstFirst 12
  1. Posts : 8,135
    Well, no one else that I have seen post has been able to get both working at the same time. I'm on several forums other than this one and its the same on all the forums that I'm on.
    The Windows standard is to only have one default audio playback device.
    There are a lot of people that would like to have both.
  2. Posts : 80
    Windows 7 64bit Ultimate (Retail)
       #12
  3. Posts : 8,135
    Looks like the tweak works for some and not others.
  4. Posts : 80
       #14
    Well it took some digging but it's been done, in case others come across the same problem some of these links may be of help.
    How do I get Audio to two places (HDMI & Mini Out) [Solved] - Sound Cards - Components
    Is it possible to get audio in Windows 7 through HDMI and PC Speakers - Microsoft Community
    Is it possible to play sound both from PC speakers and out via TV?
    There is also a bit of software which is supposed to be able to do this as well but i never got round to testing it, it's called "Virtual Audio Cable" and can be found here: Virtual Audio Cable Home Page
    I found out about it from this thread here: Is it possible to play sound both from PC speakers and out via TV?
    Good luck to anyone else trying to sort it, it was a real pain from my POV took 3-4 days to sort but i knew it could be done somehow, i hope the above links helps others.
    All1
