Your built in microphone volume keeps changing itself on skype
  1. Posts : 6
    Windows 7 Ultimate 64-bit (6.1, Build 7601) Service Pack 1
    Whenever you make video call on skype with friends your microphone volume just automatically changes by itself i will turn it up all the way to 80/100 and it always ends up going down to 20/100 and then your friends won't hear you.i also faced this kind of problem so here is an easy solution.
    When you using Skype or MSN
    Go to your Webcam and Mic/Audio setup and uncheck the box where it says to automatically adjust mic volume.
    and your problem would be solved take care hope you like it.
  2. Posts : 2,196
    Win7, Win10, Win11
    Hello Niaz,
    Here are some other solutions, as well.
    http://community.skype.com/t5/forums...rophone+volume+
    John
      My Computers
