Using a Graphic Equaliser With Realtek Audio?
  1. Posts : 6
    Win 7 Home Premium 64 bit
    As requested.
    The window on the right is what i get when i click on HD audio manager in control panel, the window on the left when I plug in headphones.
    Sorry it took so long ive been busy all week.
  2. Posts : 2,752
       #12
    jargraj said:
    As requested.
    Did you intend to post a screenshot? Nothing shows. Please edit and try again.
  3. Posts : 6
    It shows for me when I click on the little image button, I can't figure how to embed an image in the post? It should function as a link to my dropbox
  4. Posts : 2,752
       #14
    As you can see from Chris Nicola's post #7 above (he, too, posted a Dropbox picture), if you just paste the dropbox URL for the JPG itself into your post, that will provide a usable link in your post that we can click on to see the image. Don't use the "insert image" button.
    Normally, inserting an image and having it display in the post itself (as I have done is my own post above) is done by manually sandwiching the URL for the image between a "start image" and "end image" delimiter, i.e. "[ i m g ]" and "[ / i m g ]" (with the spaces removed). But this works for me because I use ImageShack as my web repository for photos that I share this way... I don't use Dropbox.
    URL's from ImageShack work fine as the pasted contents for the "insert image" button (and then push the OK button) and that picture is inserted properly and visibly into the post, but Dropbox must not work the same way. Just paste the Dropbox URL for the JPG in your post, as Chris Nicola's done, and then we can click on the link ourselves to see the picture from Dropbox.
  5. Posts : 1,364
       #15
    I too am not able to view the eq, only presets. See attached screenshot - How do I get it to display?
    -thx
    Attached Thumbnails Attached Thumbnails Using a Graphic Equaliser With Realtek Audio?-rtmeq.png
  6. Posts : 6
       #16
  7. Posts : 1,364
       #17
  8. Posts : 2
    I'm in the exact same situation as jargraj, and I think we even have the same laptop... This problem has been bothering me ever since I bought this laptop, and I never found a solution for it. I really hope somebody can give jargraj and me a solution for it, because it really sucks.
    I'm sorry I might have resurrected the thread, but this is the first time I found a relevant thread for my problem.
    I hope to see a solution real soon.
    Thanks in advance
  9. Posts : 170
    Desktop Win 10 Pro 64 bit, Laptop Win 7 Home 64 bit
       #19
    In Control Panel /Realtec HD audio Manager can you see the following screenshot? Click the equalizer icon (circled at the bottom) to make it appear.
    https://www.dropbox.com/s/xhnq0w65kc...altec.JPG?dl=0
    Kind Regards
    Chris
  10. Posts : 2
    No I don't even have 4 tabs for my speakers... I only have 2: speaker configuration and default format. ThaThat's the problem.. On my pc downstairs I do have the same window like in your screenshot, but my laptop does not
