sigmatel c-major audio
Page 2 of 2 FirstFirst 12
  1. Posts : 9
    windows 7
    i tried those driver also and they did not work i used to use them when i reformatted with xp and they worked but no dice with win 7
  2. Posts : 9
    windows 7
       #12
    i tried that several times that driver only worked for me when i installed xp hasnt worked since i installed win 7
  3. Posts : 5,747
    7600.20510 x86
    Alright Sweny. I must be having a brain slowdown. I had a better look at the .inf for what I previously gave you and that is not designed for your hardware. Completely my error (and also resource I used to get it.)
    Let me give this a little better attention. I know how important it is to you to get this working.
    I will download what Jabau gave you right now to see if I can figure out why it will not install for you. I'll post back with my findings or whatnot in an edit to this post in a little bit.
    EDIT -
    Sweny. I see no reason at all why Jabau's driver does not work for you. It is correct and contains this line in the .inf which is for your device.
    "%STAC97.DvDscInt%=STAC97, PCI\VEN_8086&DEV_266E&SUBSYS_01821028"
    Run the .exe so it extracts to C:\Dell
    Install with device manager after it extracts, using the .inf.
    Right click audio device, update driver software, browse, let me pick, have disk, browse.
    When at browse step, navigate to C:\dell\drivers\R99254\WDM
    and choose Stac97.inf
    Thanks Jabau. +1 rep
  4. Posts : 9
    windows 7
       #14
    well i tried that is the same driver ive been using with no luck ive dl'd it 10 times each time i try to install it says file is corrupt or missing
  5. Posts : 3
    Windows 7 Ultimate
       #15
    Maybe your download is getting corrupted, here is a zipped up copy of the driver files, taken from my D610. If when you extract this it ends up corrupted then there is a good chance that something is wrong with your connection that is damaging the files you download.
  6. Posts : 9
    windows 7
       #16
    Well first of all I'd like to thank you guys for all the help but it looks like I'm gonna have to start all over and reinstall win 7 and try again
  7. Posts : 1
    windows 7 home premium
       #17
    dell d610 sigmatel audio
    I had this same problem on my dell latitude d610.
    Here is what worked for me. I downloaded the driver from the dell website.
    http://ftp.us.dell.com/audio/R99254.EXE
    right clicked on the download, clicked properties, under compatibility I chose run this program in compatibility mode for windows XP service pack 3, clicked ok. Then followed the dialogs.
    No guarantees but it solved my sound problem.
  8. Posts : 1
    win7 home
       #18
    Just registered to thank you all!
    These worked for me !
    torrentg said:
    Does this do anything for you? Run it in Vista compatibility mode if it refuses to install. If not, give me the info I asked.
    SIGMATEL Audio AC97 for ICH4 6.14.01.3900 free driver download
    I have a Sony PCG 8N2M
  9. Posts : 3
    I work on many machines.
       #19
    VEN_8086_DEV_266E
    It might be too late...but I was having this same problem with a Windows 7 32 bit IBM ThinkCenter A51 machine.
    Sound not working and no driver for the sound card (multimedia audio).
    The VENDOR was 8086 and DEVICE of 266E and I kept trying all kinds of drivers but none worked. Kept giving me code 10 can't start in device manager.
    The solution was to download the AC'97 driver from the www.realtek.tw/downloads webpage.
    1) http://www.realtek.com.tw/downloads/
    2) AC'97 Audio Codes (Software)
    3) click on the "I accept" button and click on next
    4) Choose your operating system:
    I chose this:
    Vista/Win7 (32/64 bits) Driver only (ZIP file)
    5) I downloaded this file:
    6305_Vista_Win7_PG537.zip (29.6MB)
    6) I unzipped the file and installed it and now it is working.
    7) Rebooted just to be sure and still worked.
