Sound Devices Have Disappeared
Page 3 of 8 FirstFirst 12345 ... LastLast
  1. Posts : 6,458
       #21
    More reference links:
    M-1620 overview
    M-1620 specs
    Microsoft Update Catalog query=sigmatel
    You'll have to log in to MS Catalog, but hold off on downloading anything yet. I'm still digesting other data and a few dormant brain cells are firing.
    Can you post a Sound -> Recording tab screen shot? Yeah, I know - it's a playback issue - the awakening brain cells almost recall a similar issue and recording was involved - go figure. A look at your tab might jar the old memory.
    Once I absorb the M-1629 information I can better advise what drivers to try - you might have to work around the installation by using Dev Mgr to install the driver (avoiding a restart when the device is reportedly not found) or setting compatibility to Vista SP2.
    Thanks,
    Bill
  2. Posts : 678
    Windows 7 home premium 64 bit
       #22
    Slartybart said:
    Ok, now the question is why are there no speakers, most laptops have built in speakers.
    Well...., yes there are built in speakers. The thumbnail is what device manager and Playback looked like on Friday when I finally got the sound working with the internal laptop speakers. Of course it all went away when I rebooted. So to emphasize, the thumbnail is not current - it's from 2 days ago.
    Slartybart said:
    Some devices have a checkbox or it prompts you to remove the software (driver?) when you uninstall a device. You don't have to look elsewhere and it appears that the HD Audio Device is down to the base MS driver. This is where I wanted to get - a base level.
    I'll look at the 1629 information, there are some M series with Intel boards and some with Gateway boards.
    Launch Services and export the list to a Text (Tab Delimitated) (*.txt) file and attach that output to a new post. I want to check the current status of the audio services.
    Oh, and I uninstalled Speccy and reinstalled - got the same server error as the screen shot I posted.
    Attached Thumbnails Attached Thumbnails Sound Devices Have Disappeared-capture12.png
    Sound Devices Have Disappeared Attached Files
  3. Posts : 678
       #23
    Slartybart said:
    A quick test would be to disable the Digital Audio (S/PDIF) device and see how the machine behaves. After a bit more reading, I might suggest uninstalling that device, but wait until I read more.
    Could you attach the Windows Update (WU) log to a post? I'm wondering if WU 'helped' you with driver updates.
    C:\Windows\WindowsUpdate.log
    No change after disabling the device other than the red X
    Attached Thumbnails Attached Thumbnails Sound Devices Have Disappeared-capture18.png
  4. Posts : 678
       #24
    Recording Tab screenshot
    Attached Thumbnails Attached Thumbnails Sound Devices Have Disappeared-recording-tab.png
  5. Posts : 6,458
       #25
    Thanks, I'll be posting in this thread - yeah Speccy is a Piriform server issue.
    What screenshot is this?
    Current or two days ago - because this looks pretty good (speakers=default) except the ATI HD device is back. This is most likely being installed after a restart and is probably causing the sound issue. The BSOD might have been a result of the AMD HD 'update' to the ATI device. AMD/ATI are same company now, but these are old drivers (2004-2008) and then there's the Sigmatel/IDT 9205 device itself.
    All of this worked at some point, right, so it's just a matter of unwinding the changes/updates.
    So.... I'm confused. It's probably better to post screenshots with current information and provide a link reference to previous information (for me anyway).
    Words often get in the way of communicating - this sort of threw me off
    I wasn't sure which thumbnail was from 2 days ago, although I did not see a post with this information (so I assume this is current)
    Bill
  6. Posts : 6,458
       #26
    boweasel said:
    Slartybart said:
    Seems as though the driver rolled back (AMD to ATI)
    Uninstall the ATI HD Audio device, remove software if option is present
    Uninstalled the ATI HD Audio device and rebooted. Got this.
    Can you get back to this?
    Also, there should be a built-in microphone, right? Try disabling both of the mics shown on the
    One should be an internal mic and the other references the 3.5 jack
  7. Posts : 678
       #27
    That was from post #22 in this thread, and I emphasized that the image was from this past Friday, the 7th of March, and yes, when that image was taken I had working sound from the internal speakers.
    Maybe I could have made that clearer.. You asked (post #19 of this thread) 'Ok, now the question is why are there no speakers, most laptops have built in speakers.' In post #22 I answered that and gave you the screenshot of the playback tab as it looked when the sound was working. I've saved all the screen images so I can refer to them later. The image from #22 was simply one I took and kept to sort of prove to people that I DID have sound.
  8. Posts : 678
       #28
    Post #12 Sound Device / Driver Problems Causing BSOD shows what I have now
    Since I currently have no audio device installed, the Recording tab looks just like the Playback tab
    Attached Thumbnails Attached Thumbnails Sound Devices Have Disappeared-capture20.png
  9. Posts : 725
    Desk 1: Win 7 Pro x32; Desk 2: Windows 10 x64
       #29
    By definition, HD Audio Devices connect to an upstream HD Audio bus controller. As i understand it, the first problem to tackle is audio devices don't always appear in DevMgr? In any case, I'd first refresh the controller.
    The HD Audio bus controller appears in DevMgr under System Devices. Find it, right click->Uninstall. At top of DevMgr menu click Action->Scan For Hardware changes. Windows will reinstall the controller. The HD bus controller will attempt to re-detect attached HD devices. Do the HD audio devices re-appear? (they may not have the right names till the thieir driver is installed - but that's the next step after detection)
  10. Posts : 6,458
       #30
    Ok, good enough.
    This is the current Dev Mgr - correct?
    What happened to the High Definition Audio Device in post# 18 (this thread)?
    I was going to ask you to copy the hardware id for the HD Audio device on the details tab of Dev Mgr, but now I have to try to find it in the other info you posted since it doesn't appear any longer.
    Try the MS Catalog for the Sigmatel driver. It's a few mods ahead of the one on Gateway and it lists Win7 as an OS.
    Click here You have to register the 1st time you use the MS Catalog.
    Description: SigmaTel Audio software update released in February, 2008
    Architecture: X86
    Classification: Drivers
    Supported products: Windows 7 , Windows 8 , Windows 8.1 Drivers , Windows Vista
    Driver Manufacturer: SigmaTel
    Driver Class: Other Hardware
    Driver Model: SigmaTel High Definition Audio CODEC
    Driver Provider: SigmaTel
    Version: 6.10.5866.0
    Version Date: 2/15/2008
