No sound, cant fix it, dont know whats wrong.
  1. Posts : 3
    Windows 7 64 bit
    So... i've created this account just to try and get this finaly solved.
    I've had no sound for a long time and i've been trying to find a fix for months...
    I formated my pc 3 times now and still nothing.
    I dont know whats going on exactly... this is all I know:
    -No speakers/headphones work no matter in which jack i plug them into (front or back)
    -On Playback Devices it only shows "Digital Audio (HDMI)" which says its not plugged in, and "Digital Audio (S/PDIF)" which says its working... but I get no sound from anything (speakers/headphones) no matter where I plug them into.
    -On the device manager - sound, i only see 2 devices both named "High Definition Audio Device", and i've tried intalling Realtek from the links on this forum... nothing at all happened.
    After saying install was completed... it didn't install, nothing new on the devices manager... just nothing changed. Why!
    -I have no idea what my pc manufacturer is as the pc case says "VENTO AK" and on the system information theres OS Manufacturer as "Microsoft Corporation" and System Manufacturer as "To Be Filled By O.E.M."
    -On system information says that the Sound Device manufacturer is Microsoft.
    I'll gladly give any more information required to help... if you point me to it.
    I just want to have sound on my pc...
  2. Posts : 1,810
    Dual Boot: Windows 8.1 & Server 2012r2 VMs: Kali Linux, Backbox, Matriux, Windows 8.1
    Sounds like you need a driver. Download Speccy - System Information - Free Download and let us know what it says in Audio.
    If you need help, see: Find Detailed Hardware Information with Speccy
  3. Posts : 4
    I have the same problem, see my post. Are your audio jacks or speakers outputs also not showing up in the panel?
    My post: No sound from rear audio jacks after installing W7
  4. Posts : 3
    Windows 7 64 bit
    I downloaded that Speccy thing.
    On audio is says:
    Sound Cards
    Playback Device
    Digital Audio (S/PDIF) (High Definition Audio Device)
    Recording Devices
    Microphone (High Definition Audio Defice) (default)
    Line In (High Definition Audio Device)
    Microphone (High Definition Audio Device) (default)
    So what now...
    To the other post, nothing shows up on the playback devices if I plug speakers/headphones to any jack (front or back) of the computer.
