"Scan for Hardware Changes" fixes audio problem, but problem returns
  1. Posts : 5
    Windows 7 Home Premium, 32 Bit
    Hi all,
    Issue: The sound on my internal laptop speakers does not work when I try to play audio.
    Solution:
    However, if I go into "Device Manager" and click "Scan for Hardware Changes" on the "Sounds, video and game controllers" section, my sound returns instantly. The moment I click "Scan..." the sound appears straight away and plays back without issue.
    The Problem:
    Problem is, while the sound plays back fine as long as I am playing sound, the problem of no sound returns once I stop audio payback. I've noticed I can stop playback and the sound will still play back for a minute or two, but if I don't play audio for longer than about 5 minutes the sound again disappears next time I try to play back and I have to do the "Scan..." thing again to get it working. It's as though my system keeps defaulting back to an incorrect setting or something after a few minutes.
    External Speakers: There is no problem at all when I have my (bluetooth) external speakers selected. Sound plays through them fine.
    What I've tried to fix:
    - Troubleshoot both "Playback Audio" and "Hardware and Devices" through Control Panel, but neither fixes issue
    - Update Driver Software for my "Conexant High Definition SmartAudio HD2", but it says I'm up to date
    - Read the forums to find my specific problem, but couldn't...apologies if I've missed it.
    From Speccy > Audio
    - Sound Cards
    Bluetooth Hands-free Audio
    Bluetooth Stereo Audio
    - Playback Devices
    Speakers (Conexant High Definition SmartAudio HD2) (default)
    SPDIF Interface (Conexant High Definition SmartAudio HD2)
    From Speccy > General
    Operating System
    Windows 7 Home Premium 32-bit SP1
    Intel Mobile Core 2 Duo T5200 @ 1.60GHz 69 °C
    Merom 65nm Technology
    RAM
    4.00GB Dual-Channel DDR2 @ 266MHz (4-4-4-12)
    TOSHIBA Satellite P100 (U2E1) 70 °C
    Graphics
    Generic PnP Monitor (1440x900@59Hz)
    Intel Mobile Intel 945 Express Chipset Family (Toshiba)
    Storage
    93GB TOSHIBA MK1032GSX ATA Device (SATA) 39 °C
    Optical Drives
    MATSHITA DVD-RAM UJ-850S ATA Device
    Audio
    I hope that's as much information as you guys need to help me. Advice much appreciated.
    Thanks.
    Please post a screen shot of the Device Manager/Sounds section.
  3. Posts : 5
    Hi Fireberd,
    Screen shot of the Device Manager/Sounds section as requested:
    "Scan for Hardware Changes" fixes audio problem, but problem returns-dev-audio.png
  4. Posts : 8,135
    The Bluetooth is suspect. What shows up in the Control Panel/Hardware and Sound and finally the Sound panel playback? If it is setting the Bluetooth as the default Playback device, the speakers will not work.
  5. Posts : 5
    Screenshot when BT is off:
    "Scan for Hardware Changes" fixes audio problem, but problem returns-play.png
    And when BT speakers are switched on:
    "Scan for Hardware Changes" fixes audio problem, but problem returns-play-2.png
  6. Posts : 8,135
    Do this, if there is any Windows corruption with the Conexant HD Audio it will fix it.
    Go to the Device Manager, RIGHT click on the Conexant entry and then LEFT click "Uninstall". DO NOT check the box to also uninstall the drivers Restart the PC and when Windows starts it will detect and reinstall the Conexant. This fixes a lot of flakey problems.
  7. Posts : 5
    I tried this last night - Windows didn't re-install the Conexant when I re-started my computer, but I ran a manual Windows Update and that re-installed Conexant, although it didn't fix the sound problem.
    I then gave your suggestion a second try...but again Windows didn't re-install the Conexant automatically and when I tried to do it manually it didn't find any updates that way either.
    Now, the sound icon in my tray is showing "No Audio Output Devices Installed", with a red cross over the icon. When I re-start computer, it doesn't seem to recognise that the component is missing. Troubleshooting "Sound Problems" doesn't re-install/fix it either.
    Ugh, not sure what's going on...
  8. Posts : 725
    Desk 1: Win 7 Pro x32; Desk 2: Windows 10 x64
    1. Look in Programs and Features, see if Conexant audio entry. If yes, uninstall it from there
    2. Go to the Toshiba support and use the driver you find from Toshiba for your specific model
    3. When BT installed (see your 2nd screen shot) note you must set speakers back to default device for them to output sound (in your screen shot BT is default)
    4. Ctl Pnl->Sounds. Right click the speakers. Select Advanced tab. Make sure exclusive mode is turned off
    5. If you still have a red X, go to DevMgr, right click the audio driver->Properties->General tab. Under Device Status what's the numeric code?
  9. Posts : 5
    Hi ComputerGeek - thanks for your input.
    My red X is gone after I performed a Manual Windows Update, so I guess the system eventually found the missing componant.
    On my original issue, the reason I chose the thread title "Scan for Hardware Changes" fixes audio... was because I thought it might be possible to infer something from that fix. In other words, if "Scan for Hardware Changes" is the solution, perhaps we could work back to identify the problem?
    I'm not a PC guy, but it seems to me that the computer has all the components it needs to play sound, but for some reason it keeps on defaulting back to a state that doesn't recognise some kind of hardware change/configuration that I instead need to manually prompt it to search for. As I mentioned, clicking "Scan for Hardware Changes" restores the sound the instant I click that option and the box appears saying "Scanning Plug and Play Compliant Hardware".
    I could be on totally the wrong track there, but I'll throw it out there.
    Thanks.
  10. Posts : 725
    I'm not a PC guy<snip>
    You may not be a computer guy, but you sure think like one!
    Disconnect or disable BT. I don't BT as an audio option during these tests. Also, I'm assuming your audio driver is installed - whether it's working or not, as long as it's installed. Do the following
    1. Click Start. In the search box type dxdiag. Hit enter
      • If you are running 64-bit Windows, you'll see a 64bit Dxdiag button at the bottom of the window
      • Click it to generate a 64bit dxdiag report
      • Now click the Save All Information button, save as a text file, and upload the report to next post
    2. Right click the audio device in DevMgr->Properties->Details. Scroll down and look for Upper and Lower Class Filters (see pic below)
      • If one or other doesn't exist for the device, you may not see an entry. But if either exist in the pull down menu, select them. Then copy/paste what you see for each
    You can probably only do the following when the driver is installed and there's no device error in DevMgr
    > Verify your speakers are the default device
    > Turn off exclusive mode on your speakers. (See my post #8)
    Attached Thumbnails Attached Thumbnails &quot;Scan for Hardware Changes&quot; fixes audio problem, but problem returns-filters.jpg
