Crackling and popping audio.
  1. Posts : 87
    Hi all;
    Question about the audio on my laptop. Have any of you ever experienced "popping" during audio playback? It says the drivers are working ok. It never threw a code or anything. Any suggestions, ideas as to goings on?
    This is a fairly common complaint, although there haven't been many lately. If you search through the postings here you will find a lot of them. Unfortunately there is no "one fix" for this problem. Drivers are one issue, make sure you have the latest (and correct) driver for your sound device. Video card drivers is another known cause. Wi-Fi is another known cause.
    Just have to start, one at a time, updating drivers and trying to isolate what the problem is.
  3. Posts : 87
    Thanks fireberd,
    Now that you mention it, I'll maybe re install some drivers and that might fix things.
  4. Posts : 87
    Quick update; reinstalled my audio drivers. Seemed to have solved some problems.
