Burned CD music skipping--multiple culprits possible
I used ImgBurn to burn some MP3s to a CD. Once burned most skip, with blank bits of silence (they sound perfect on the PC players). Even though the burner was tested to check everything and was used at half its speed. I then, just for testing purposes took those same MP3s and put them through Audacity, did a checksum thing, deleted the first few and last few 'empty' seconds from the MP3 files, added 2 seconds of silence and then converted them to wav--all this to test and see if the skipping would still happened and it did. So is problem the actual CDs, is it my CD/DVD Burner ( a brand new one) Or is it the files themselves? and if the files how can one test such files (and fix them) in order to avoid wasting CDs? thank you
OS: windows 7 Home Prem. 64 bit
Burner: ASUS DRW-24B1ST i
