Difference between Audio Cable and Aux Cable
  1. Posts : 4,198
    Windows 10 Pro
    Hello I have a quick question! what is the difference between Audio Cable and Aux Cable? Is there any difference in sound quality or in Left Right Channel Sound? I'm asking because I recently bought Edifier C2 2.1ch Sound System for my PC that has an External Amplifier that has Aux Input as well. Reason is I'm asking coz I want to hookup my PS3 with it as well that through the Audio Cable as PS3 sound output isn't working on the Aux but I primarily use this audio system with my PC as I use it more frequently.. so was wondering to hook the PC with Aux and PS3 on the Audio input.
    Depends on what type of audio signal you are dealing with. Low level audio should use "shielded" audio cable. Speaker links can use "speaker" cable.
  3. Posts : 4,198
    Windows 10 Pro
    I'm using both good quality cables... I bought a Aux cable for $2 today and the audio cable comes with the Edifier C2 and PS3 has it's own original cables too
  4. Posts : 8,135
    I'm an ex-guitar amp tech and electronics tech but still not sure what you have or what you are calling what.
