Sound issue !
  1. Posts : 11
    Windows 7 x64
    Sound issue !
    Hello everyone !
    I have a HP Compaq Presario v6000,and i reformated to windows 7 and i have a sound problem with my laptop.
    The sound works on laptop speakers,but when i plug in headset and microphone the sound doesn't go to headset but it still on the laptop speakers.
    I plug in the headset and microphone and it doesn't show in the playback or recording devices tab.
    Please help !
  2. Posts : 1,810
    Dual Boot: Windows 8.1 & Server 2012r2 VMs: Kali Linux, Backbox, Matriux, Windows 8.1
    Hello simply and welcome to Seven forums!
    Can you post a picture of your Device Manager?
    Go to Start > In search start typing "Device Manager". You will see "Device Manager" in the results.
    Next, expand Sound, Video and Game controllers. You can then use the "Snipping Tool" (same process as above but search for Snipping Tool)
    Next, highlight the area around the Device Manager windows and save it to your Desktop. Come back here and click the Paper clip Icon next to the Smiley face. Click "Browse" and then find your snip on your desktop and upload it.
  3. Posts : 11
    Windows 7 x64
    Here it is,in the device manager it shows that is ok :
  4. Posts : 1,810
    After you click Browse, make sure you select "Upload" as well
  5. Posts : 11
    Windows 7 x64
    Ye got it.
  6. Posts : 1,810
    Did you update all of your drivers after you reinstalled ? You should have a disk with the drivers necessary that came with your PC. If not, go to the link below.
    Go here, it should automatically detect your product and you can download drivers from there.
    NVIDIA Driver Downloads - Automatically Detect NVIDIA Products
  7. Posts : 11
    Windows 7 x64
    Leatest driver from nvidia on my laptop is GeForce 307.83 Driver.
    When i try to install the driver a problem pop up "Install Cannot Continue - The Graphics Driver Could Not Find Compatible Graphics Hardware."
    I found fix in this website https://forums.geforce.com/default/t...re-installer-/
    I have follow all the steps but in the step 7 i don't have the inf files.
    7. there will be many INF files there of the type:
    nvaa.inf
    nvac.inf
    nvam.inf
    nvao.inf
    nvbl.inf
  8. Posts : 8,135
    Looking at the screen shot of the Device Manager, I see "High Definition Audio Device" which is usually the generic, basic function, Windows installed sound driver. First step is to get the correct sound driver and install that.
    HP lists a Conexant Vista driver for this model. The Vista driver is applicable to Windows 7.
    Conexant High-Definition Audio Driver - Compaq Presario V6003AU Notebook PC | HP® Support=
  9. Posts : 11
    Windows 7 x64
    Just downloaded and was trying to install but it won't install it says failure
  10. Posts : 8,135
    Try installing it in Compatibility mode for Vista. Right Click on the Install Icon and then Left Click Properties. One of the tabs in the Properties panel will be for Compatibility.
