Windows 7: No sound from HDMI device Nvidia and Realtek HD Audio
29 Oct 2009   #11
ba5ik
Windows 7 Ultimate x64 RTM
do you have an optical S/PDIF port on the back of your motherboard?
looks like this http://www.yourdictionary.com/images...r/_TOSLINK.JPG
29 Oct 2009   #12
amzo
Windows 7 64Bit
Quote   Quote: Originally Posted by ba5ik View Post
Yep I do have an optical in and out....But I dont really want to order a cable and use that as it is not really ideal....Was hoping to get sound working via the HDMI port?...Is there a way to disable the optical sound ports so maybe the HDMI passthrough for sound maybe kicks in?
Thank You
I am about to install http://downloads.guru3d.com/Forcewar...load-2419.html to see if this helps?...If I do go offline it will be very breif.
29 Oct 2009   #13
stormy13
Microsoft MVP
Win 7 Ultimate x64
You have a picture of your card? Just found this,
and a picture of it,
and if your card is anything like that on (or even the 7600GT I used to have), there is no way that you were getting audio over HDMI as the DVI ports don't support it and there is no SPDIF connector on the card (to allow audio pass-through) like there is on the 8800 series and up,
Guide: 8800GT/9800GT/9800GTX Sound over HDMI (Now including Creative cards) - Overclock.net - Overclocking.net
(no idea why those Gateway links are like that)
29 Oct 2009   #14
ba5ik
I am going have to agree with stormy13, even if you have an HDMI out on the card there is no way to get audio through it with a pass-through connection.... So unless you are mistaken on the model of your card I am stumped.
29 Oct 2009   #15
amzo
Windows 7 64Bit
Quote   Quote: Originally Posted by stormy13 View Post
Nope mine definately has monitor out,DVI and HDMI ports (3 seperate outputs) it was a Medion MD 8818 PC bought in Dec 2006..Could it be the driver is finding the incorrect graphics card?...
No sound from HDMI device Nvidia and Realtek HD Audio-screenhunter_02-oct.-29-17.28.gif
29 Oct 2009   #16
ba5ik
do you have anything plugged into the front audio ports? if yes unplug it, could you also post a screen of your realtek control panel also are you comfortable opening your case?
29 Oct 2009   #17
amzo
Windows 7 64Bit
Nothing plugged in the front, comfortable to open PC...and by realtek control panel...Do you mean the Sound Manager...
No sound from HDMI device Nvidia and Realtek HD Audio-screenhunter_04-oct.-29-17.34.gif
29 Oct 2009   #18
ba5ik
show us the digital output tab
29 Oct 2009   #19
stormy13
Microsoft MVP
Win 7 Ultimate x64
Nice that doing a search Medion doesn't even turn up that model (8818). Anyway a little persistant searching and I found this,
Aldi Medion media centre machine? - AVForums.com
rather nice of the guy in post #7 to copy and paste all of the specs for it. That said after looking it over twice I can find zero mention of that card being able to do audio over HDMI (and that card is very rare FWIW). The only thing it lists for audio is the following,
Quote:
Home-cinema experience:
8 channel High Definition Audio Out (Analog + S/P-DIF) For the digital home experience with optimum sound*****
The digital home cinema experience with perfect sound*******
*******Only when used with appropriate speaker systems (not supplied)
So unless the card has some kind of onboard audio of its own (like the ATI HD series) or a SPDIF header on it like the 8800 series (to connect to the SPDIF header on a sound card or on the motherboards onboard sound), I don't see how you managed to get audio over the HDMI connection.
29 Oct 2009   #20
amzo
Windows 7 64Bit
Medion MD 8818 - Cable Forum in the spec it does say 7650 with HDMI connection and 100% I really did have sound over the HDMI!
No sound from HDMI device Nvidia and Realtek HD Audio-screenhunter_01-oct.-29-17.45.gif
Realtek HDMI+NVIDIA = no sound+frezze screen using pc rear audio jack
Hi every one i am new at this i might carry on please forgive me if that happens. i am having this Realtek HDMI+NVIDIA =No Sound issue + if i connect back to my rear audio jack with my speakers its fine to listen music but it freeze the screen during game play and gives out a loud buzz sound than...
realtek high definition audio device - no sound
Hi, I just got a new PC and I can't get the sound to work. My PC has the following specs: Microsoft Windows 7 (6.1) Enterprise Edition 64-bit Service Pack 1 (Build 7601) DirectX Version 11.0 CPU Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz Mainboard Model ...
HDMI Audio Out, Realtek + Nvidia
Hi Guys, I really need some help with this one. I purchased a new PC, with a Gigabyte GA-H61MA-D2V motherboard that has on board realtek audio, I also purchased a nvidia geforce GT630 graphics card which has a built in audio processor and hdmi connection which is going to my LG 42PL6010 tv. ...
5.1 Sound doesnt work at Realtek High Definition Audio Device
Hello, Some time ago i was tried to connect my 5.1 creative speakers to my laptop and when i wass connecting one by one the cables windows 7 asked me what speakers it will play ( Rear, Front, Center) but now i try to connect them again and it does not ask me that ... and only 2 speakers and sub is...
Realtek HDMI+NVIDIA vc=No Sound
Hi to all. A lot of people have this problem and I've read everything in tihs forum regarding it (in other forums too) but I still can't get it fixed. When I connect my HDMI with the TV I get picture but no sound.Here's what I've tried so far : -Installing lates Realtek 2.51 and NVIDIA...
