Windows 7: No sound from HDMI device Nvidia and Realtek HD Audio
06 Nov 2009   #31
amzo
Windows 7 64Bit
Hi Patrick,
Try uninstalling both drivers and reboot in safe mode and remove drivers (for realtek and Nvidia) using a program called driver cleaner pro (look for it on the net)after that, reboot and install the video driver I had used (as mentioned on previous page...link provided) then reboot and then install realtek driver...not sure which release I used but is version 6.0.1.5953, below are a few screenshots including my current settings..the passthrough option is in 3rd screenshot (try it with and without the tick)
No sound from HDMI device Nvidia and Realtek HD Audio-screenhunter_01-nov.-06-10.36.gif
No sound from HDMI device Nvidia and Realtek HD Audio-screenhunter_02-nov.-06-10.36.gif No sound from HDMI device Nvidia and Realtek HD Audio-screenhunter_04-nov.-06-10.38.gif No sound from HDMI device Nvidia and Realtek HD Audio-screenhunter_03-nov.-06-10.37.gif
06 Nov 2009   #32
jackbrack81
windows 7
I installed windows 7 on my acer aspire 6920 hdmi was working fine till i changed my os now no sound.nvidia geforce 9500m g/c tryed to recover my orig vista disk but no good i would gladly go back if i could...can anyone help please?
06 Nov 2009   #33
amzo
Windows 7 64Bit
Jackbrack81, Need more info....Are u on 32 or 64bit OS?...Have u tried the nvidia driver I mentioned in this thread??...As much info as possible plz...
06 Nov 2009   #34
jackbrack81
windows 7
Amzo iv sorted it m8...thanx anyway
http://uk.download.nvidia.com/Window...ional_beta.exe
that works 100% on geforce 9500m gs
06 Nov 2009   #35
amzo
Windows 7 64Bit
Superb....
08 Nov 2009   #36
patrick
w7 ultimate
still no audio over hdmi
Quote   Quote: Originally Posted by amzo View Post
Hi Patrick,
Hi Amzo,
Thanks for your detailed advice... I tried it the way you suggested... unfortunately with no success
The only thing happended was, that my HDTV is now making a Tick-Sound in a fast interval even when music is not playing... it stops when i aktivate "Mute" on my digital out device !!??
But with the new Nvidia Driver the HDTV properties dialog from the NVIDIA control panel alows the option to have HDMI with or without audio.
But it still doesnt work anyway
anyway, thx for your help.
08 Nov 2009   #37
dimitar
Windows 7,Ubuntu,Fedora,Windows XP
Hi,i had the similar problem with HDMI too...all you need to do is to update your windows 7.
in the list of updates you gonna see you sound and HDMI drivers.
09 Nov 2009   #38
patrick
w7 ultimate
unfortunately that doesnt work for me ... I dont get any updates for HDMI or Sound via Windows Update. Win7 Installation includes drivers for my Nvidia 7650GS ... which are installed automatically if I deinstall the new downloaded NVIDIA drivers.
09 Nov 2009   #39
amzo
Windows 7 64Bit
not sure then mate...my 7650GS definately started working after I installed that driver
14 Nov 2009   #40
plapic
Windows 7 Ultimate
MD8818 Unknown Device - Suspect USB Network Wireless
Hey Amzo
I too have MD8818 but have come across a different issue and would like to know if you have it too. I have Windows 7 Ultimate 32bit installed not 64bit.
My network wireless for some reason no longer works.
I have found I have an Unknown Device and suspect it may be the wireless usb network.
Unknown Device USB\VID_0000&PID_0000\6&34DBCBC0&0&2 43
The rest is as follows
VIA Rev 5 or later USB Universal Host Controller PCI\VEN_1106&DEV_3038&SUBSYS_73181462&REV_91\3&2411E6FE&1&80
VIA Rev 5 or later USB Universal Host Controller PCI\VEN_1106&DEV_3038&SUBSYS_73181462&REV_91\3&2411E6FE&1&81
VIA Rev 5 or later USB Universal Host Controller PCI\VEN_1106&DEV_3038&SUBSYS_73181462&REV_91\3&2411E6FE&1&82
VIA Rev 5 or later USB Universal Host Controller PCI\VEN_1106&DEV_3038&SUBSYS_73181462&REV_91\3&2411E6FE&1&83
VIA USB Enhanced Host Controller PCI\VEN_1106&DEV_3104&SUBSYS_73181462&REV_90\3&2411E6FE&1&84
How does it compare with yours?
Realtek HDMI+NVIDIA = no sound+frezze screen using pc rear audio jack
Hi every one i am new at this i might carry on please forgive me if that happens. i am having this Realtek HDMI+NVIDIA =No Sound issue + if i connect back to my rear audio jack with my speakers its fine to listen music but it freeze the screen during game play and gives out a loud buzz sound than...
realtek high definition audio device - no sound
Hi, I just got a new PC and I can't get the sound to work. My PC has the following specs: Microsoft Windows 7 (6.1) Enterprise Edition 64-bit Service Pack 1 (Build 7601) DirectX Version 11.0 CPU Intel(R) Core(TM) i7-3770K CPU @ 3.50GHz Mainboard Model ...
HDMI Audio Out, Realtek + Nvidia
Hi Guys, I really need some help with this one. I purchased a new PC, with a Gigabyte GA-H61MA-D2V motherboard that has on board realtek audio, I also purchased a nvidia geforce GT630 graphics card which has a built in audio processor and hdmi connection which is going to my LG 42PL6010 tv. ...
5.1 Sound doesnt work at Realtek High Definition Audio Device
Hello, Some time ago i was tried to connect my 5.1 creative speakers to my laptop and when i wass connecting one by one the cables windows 7 asked me what speakers it will play ( Rear, Front, Center) but now i try to connect them again and it does not ask me that ... and only 2 speakers and sub is...
Realtek HDMI+NVIDIA vc=No Sound
Hi to all. A lot of people have this problem and I've read everything in tihs forum regarding it (in other forums too) but I still can't get it fixed. When I connect my HDMI with the TV I get picture but no sound.Here's what I've tried so far : -Installing lates Realtek 2.51 and NVIDIA...
