No sound from HDMI device Nvidia and Realtek HD Audio
Page 5 of 5 FirstFirst ... 345
  1. Posts : 4
    w7 ultimate
       #41
    amzo said:
    not sure then mate...my 7650GS definately started working after I installed that driver
    could you please give me a detailed "name" of that driver... maybe I can find it via google and download it on my own without windows update...
    thx
    patrick
  2. Posts : 26
    Windows 7 64Bit
       #42
    Page 3....3rd post down(in this thread)....link is there mate!
  3. Posts : 26
    Windows 7 64Bit
       #43
    plapic I have no unknown devices...I would download the vista drivers from the medion site for your PC in the support section after entering your PC serial number?
  4. Posts : 2
    Windows 7 Ultimate
       #44
    Amzo I have all drivers installed. Only the wireless driver failed as it appears that the software is not recognising the onboard USB wireless network.
    Have you check the list I previously posted and compared it with yours to see what the difference is.
  5. Posts : 8
    Windows 7 32-bit
       #45
    Hi to all.
    I've had the exact same problem as Amzo but I did everything as he did but I didn't put the realtek r 2.35 driver.After installing the nvidia 195.39,uninstallnig the realtek one,restarting the computer and letting it install it's own audio driver - it worked like a charm.You can find more info in this thread Realtek HDMI+NVIDIA vc=No Sound
    Just give it a try it won't hurt you :) Good luck to all!
