H.D. Audio not work??
  1. Posts : 10
    Windows 7 32bit ultimate
    Guys I'v been searching and reading and pulling my hair out for 3days!!
    I had Windows XP, then installed Windows 7 32bit Ultimate on IDE hard drive.
    HOW DO I GET SOUND??
    The desktop on Windows 7 shows icon on bottom right hand corner of speaker. It has a red X next to it.
    The Troubleshooting thing completes:
    Problems found
    High Definition Audio Device has a driver problem Not Fixed X
    Reinstall device driver Completed
    Check audio device Detected !
    There might be a problem with your audio device
    When I go to Device Manager it shows:
    Sound, video and game controllers
    ! High Definition Audio Device
    Also shows in System devices it shows:
    High Definition Audio Controller
    I have installed many drivers from many sources but to no avail.
  2. Posts : 5,747
    7600.20510 x86
    1) You already did clean install. Nothing more to be concerned with.
    2) try Windows Update. If nothing, right click it in device manager, properties, details tab. Change dropdown to hardware ids. Copy and paste the results to a post here.
  3. Posts : 10
    This is what it came up with
    HDAUDIO\FUNC_01&VEN_434D&DEV_4980&SUBSYS_00010083&REV_0900
    Oh and in the Generals tab it says:
    This device cannot start. (Code 10)
  4. Posts : 5,747
    7600.20510 x86
    You could try the C-Media XP driver for your board. Install using the device manager. Right click the audio device, update driver software, browse, let me pick, have disk, browse. Find the .inf now.
  5. Posts : 10
    OK the X on the speaker thing is gone....also when i play musc the visulisation seems to pick up the signals
    But no sound yet?
    When i right click the speaker icon, sound, playback, i have selected speakers as my default as it shows visulisation.
    I also have 'digital output' underneath with the same device name and is labelled 'ready'.
  6. Posts : 4
    Windows 7 Pro 64 Bit
    Welcome to my hell. I have a Vostro 200, came with Windows Vista on it, and my audio card WILL not detect that I have my speakers plugged in. My computer passed the "Can you upgrade" but unless I went to Dell and checked to make sure my model was able to upgrade...F DELL!!
  7. Posts : 10
    YES!!......I unistalled all the drivers i installed prior to your help. Now i got sound baby Yeah. Thank You TORRENTG Also i found how to load drivers so that i can do format and fresh install.
    Sleerts you should try to do what i was told:
  8. Posts : 9
    windows build 7600
    PCI\VEN_1106&DEV_3288&SUBSYS_08881849&REV_10
    PCI\VEN_1106&DEV_3288&CC_040300
    how about me? same problem any suggestions?
  9. Posts : 5,747
    7600.20510 x86
    Not sure. I really couldn't find too much on it so I attempted something for you with a slight chance of success.
    Install by using the device manager. Right click on device, update driver software, browse, let me pick, have disk, browse. Find the .inf in the XP folder where you extracted to.
    Good luck!
  10. Posts : 9
    windows build 7600
    Good luck!
    what .inf file am I looking for?
