No audio but the green sound bar on the volume control is moving?
Hey there! A few days ago I changed my hdd because the last one got corrupted and had a lot of bad sectors so I installed a new windows 7 OS. Everything was smooth until the sound suddenly stopped. I wasn't doing anything in particular. I noticed the green bar on the volume control is moving but I had no sound. I plugged headphones in - same thing. Anyways it fixed with a reboot and I thought it was a one time bug. But it happened 4 times already and the only other thing that fixes it beside rebooting is uninstalling the sound device from the device manager and installing it again. What is causing this? I downloaded my Realtek drivers and I ran them with the setup.exe file and they are currently installed on my PC but they don't seem to do anything. These are pictures from the various things I wanted you to see that look normal:
imgur: the simple image sharer
What may be causing this and how can I fix it?
