Beats by Dre headphones with mic volume low and mic is not working.
  1. Posts : 9
    When I connect my headphones to ipad or any other devices, It works fine but when I connect it to my PC at rear green port it gives me low volume and mic doesn't worked and recognised too.
    I got ports at rear of my cabinet only.
    Please give me solutions.
    Please post screenshots of the Device Manager, Sounds section, Sound Panel Playback section and Sound Panel Recording Section.
  3. Posts : 9
    Screenshot by Lightshot
    http://prntscr.com/45uiuh
    http://prntscr.com/45uj16
    And about those 2 Mic's 1 is USB mic which is in my webcam and the other was added when i used extrnal mic, i don't have it anymore.
  4. Posts : 8,135
    You did not post screenshots as I asked, using the Forum procedure.
    However, I see the USB mic is set as default. Change the Default Recording device to the Stereo Mix and then try the microphone.
    Webcam's have a history of conflicting and interfering with microphones.
  5. Posts : 9
    No the Mic is working, but I cannot listen to any sound when I try to speak in mic, I have enabled Listen to this device, I can listen some weird voices, cant listen to my own voice.
  6. Posts : 9
    Its showing the dynamic green bars moving but I cant listen to the device, Nor my voice.
  7. Posts : 8,135
    Do you have another headset or PC speakers you can connect to the GREEN Speaker jack to test?
    There are many different models of Beats by Dre. Exactly what model do you have?
    Different subject. I notice you have Win 7 64 bit but only 4GB of RAM. The 64 bit OS does you no good with only 4GB of RAM, and in fact the 64 bit version requires more system memory than a 32 bit, thus you will have less free RAM available for programs.
  8. Posts : 9
    Yes I am using Creative Speakers with a woofer and they works fine, And I use the green jack.
    I don't know about the headphones model, I got wired headphones with a mic on the aux type wire. There is written SOLO HD on side of it, I think thats the model?
    And yes it slow sometimes, But i need it for Video Editing Programs which doesnt run in 32 bit, I'll extend my Ram soon.
  9. Posts : 8,135
    Which connector do you have? 3.5mm TRS plug(s) or 3.5mm TRRS plug like is used on an iPhone and PS4?
    Attached Thumbnails Attached Thumbnails Beats by Dre headphones with mic volume low and mic is not working.-3.5mm-stereo-plug.png   Beats by Dre headphones with mic volume low and mic is not working.-ps4-headset-plug.jpg
  10. Posts : 9
    Here is image of my connector. Sorry for large and bad quality image.
    And I used it with my ipad, Never tried on PS as I don't have one, And It works with android and windows phone too.
    Beats by Dre headphones with mic volume low and mic is not working.-download.jpg
