Windows 7: Default Audio Device Problem
04 Feb 2009   #31
smokozuna
Windows 7 Build 7000
I have another PC motherboard here with VIA® P4M890/ VT8237R Plus Chipset and I am considering swapping it to see what happens.
04 Feb 2009   #32
NosferatuX
Windows 7 Build 7048 x64
Yes, it is highly likely that this is hardware related.
BIOS upgrade is normally the way to go in these cases. Check here
and just for safe measure, please install the chipset driver, here
04 Feb 2009   #33
smokozuna
OK I tried it and MY COMPUTER EXPLODED! LMAO
Just Kidding, sorry I couldn't resist. That did not correct the problem either, I have nothing better to do right now so I am going to replace the motherboard and reinstall the OS. See you in an hour!
04 Feb 2009   #34
smokozuna
Quote   Quote: Originally Posted by NosferatuX View Post
I am running the latest BIOS, great suggestions BTW. Also everything in Device Manager is working properly, no yellow question marks. Powering down be back soon!
04 Feb 2009   #35
NosferatuX
Quote   Quote: Originally Posted by smokozuna View Post
LOL! A good one! Good luck
04 Feb 2009   #36
smokozuna
Motherboards in and Setup is starting.
04 Feb 2009   #37
smokozuna
Motherboard is in and everything is installed and working but wouldn't you know I still have exactly the same problem.
05 Feb 2009   #38
NosferatuX
Please try the different USB ports to see if it yields the same results and check for BIOS upgrade on your motherboard.
Very interesting...
05 Feb 2009   #39
smokozuna
I did, the second motherboard was an Abit IP-95 and the driver support was awful, the onboard video could not support Windows 7. So I am back to the original ECS board and another fresh OS install. I am out of ideas for now. Thank You Very Much for the help everyone, I really appreciate! This forum is a very nice and friendly place to be and I feel right at home here.
15 Nov 2010   #40
Simpuhl
Windows 7 64bit
I created an app that will load in your system tray and let you change the default device
Website under review if your interested.
audio device isn't set as default, can't make it default
Hi all, Windows 7 Home Premium x64 on HP-DM1-4050us laptop, disabled a couple of unneeded services, now headphones not working, no idea which service caused this but I didn't touch either of the two required audio services (Windows Audio, Windows Audio Endpoint Builder). Audio now plays fine...
Audio Playback (Default Device Realtek) Knocks Out SRS Audio Sandbox
Hi, I finally upgraded from Windows XP to Windows 7 and almost went back shortly after finding out I could no longer organize or manually arrange my own personal files and/or folders but luckily I discovered an application called 'Folder Options X' which has re-enabled that feature for me so I'm...
Problem selecting Default Audio Device
I'm having a problem with my sound devices. I plug my headphones in, my headphones work fine in other devices, but my computer still runs the sound through the inbuilt speakers instead of through the headphones. The only program I can run through the headphones is WIndows Media Player because I...
WMP11 Play Audio through different device than Default?
Hi everyone, I got a hard question (well, at least I believe it is). When I plug my usb headset into my computer it automatically becomes the default/standard device - which is fine. When I play music, play games all the sound comes out of my headset. But lets say I want the music to be played...
ARGHHH No audio with HDMI (but it is my default device)
Yes, another thread -HDMI to HDMI from PC to TV - no sound- however my default device is my HDMI( under playback devices - I have the green checkmark and when I click on the speaker icon it show the green bars moving) still no sound. I have tryed everything - installed drivers - changed the...
