Realtek high definition audio max volume is about 50% than before,help
  1. Posts : 11
    hello. At some point I chose to reinstall Windows. I installed and updated all the drivers, etc and set the speakers up the same way as before. Only this time the audio was around 50% of the volume it was previously with volume up full. I reinstalled all audio drivers 5 times already, dont know what to do... i am running creative speakers 5.1. The drivers i have are : View image: fghfghfghfgh
    I use green jack for front speakers , blue for rear speakers and pink for center/subwoofer. Please help, i want to get my full capacity sound!! (((
  2. Posts : 40
    Windows 7 Pro
    Hi tadasjag and Welcome to Seven Forums,
    Can you roll back the driver and see if it fixes the problem?
  3. Posts : 11
    i rolled them back, now my audio manager is gone and i have only stereo speakers, need to download good manager to set jack for center, and rear speaker, cause i hear only stereo
  4. Posts : 40
    Windows 7 Pro
    Do you see in the screen shot you gave me there is a "Roll Back Driver" button over there click it (not in the picture) and follow the steps and it should roll that driver to an earlier version and it should work.
  5. Posts : 11
    Yes i rolled them back, now im missing audio manager where i can setup 5.1. in playback devices through speakers, i can only pick stereo now
  6. Posts : 40
    Windows 7 Pro
    Yes because its an old version you can now update the driver to its newest version and if you get the volume error back then it must an error with the driver not your PC.
  7. Posts : 11
    oky, then im going for the update and will post if it fixed :)
  8. Posts : 11
    It didint fix the problem ... when i man this thingy http://g-ecx.images-amazon.com/image.../6300-5_lg.jpg the max sound is like my laptops dell inspirion 15r sound when it should be 3 times greater.. (
  9. Posts : 40
    Windows 7 Pro
    Maybee its a driver problem can you try it on your neighbor or friend's PC?
  10. Posts : 11
    hm, i have a pc that i took for repairs, ill try the speakers on it. But IF the problem continues, is it possible to download some other drivers? Mother board: H61m-DS2
    I can test the speaker only in a day or 2. Need parts for the other pc to make it working.
