Yes of course you can but first just test it on another pc so we can make sure it is not your PC or OS that have the problem :).
Okey, so ill be back on this thread in about 2 days with the results :) thank you for your time and after few days, i will ask for some more of your time :))
This is how my max sound look like.................... View image: dfggdggdgggg
In playback properties of the device what are the levels set at? Also what is the program your using to play back the music?
all 100%. I use aimp3 player and sometimes vlc media player for higher sound...
http://p.globalsources.com/IMAGES/PD...Capacitors.jpg
Solved, all 20 capacitors were dead through 9 years of using.
