Sound crackling/popping
  1. Posts : 9
    Windows 8.1 64bit
    Hello!
    I have had this problem for quite a long time but I am getting enough from it.
    Basicly nearly always when I start playing any sound source there is crackling in sound at begining. Happens usually with high frequenzy sounds, adjusting volume on youtube videos or click rewinding youtube video fast, also usually when I close video there that annoying sound occurs.
    So basicly, always when someone talks in Mumble or I click to play video there is that annoying crackling/popping, it doesnt last long. Only when sound starts playing.
    Here is some pictures you might find helpful
  2. Posts : 11,424
    Windows 7 Ultimate 64
    First off welcome to SF. Second with sounds I would double check all your connections. Most often this is the pin making poor contact or even the beginning of a wire breaking down maybe from a bend or crimp. Then I would uninstall and reinstall the most current audio drivers and as well go to the mono mfgrs. site to check for other driver updates and lastly read to see if any bios updates deal with sound issues.
  3. Posts : 9
    Windows 8.1 64bit
    I didnt remember to tell you that I recently build new computer except I use Graphics card and RAM from old computer, same problem exist with this.. I have tried two different headsets
  4. Posts : 11,424
    You're using audio outputs from Mobo or GPU card?
  5. Posts : 153
    Windows Vista Business 32bit
    Do You also Receive lag During this problem too?
  6. Posts : 9
    Windows 8.1 64bit
    Plugged to mobo, frontpanel audio/microphone outputs arent even connected to mobo
    And about lag, do you mean system slowing? No nothing, no games run normally but that crackling occurs 90% of time when someone starts speaking in mumble/teamspeak
  7. Posts : 11,424
    I would start with making and unmaking the connections several times then if still happening then go to the driver re-install!
  8. Posts : 9
    Windows 8.1 64bit
    Okay, will check connections (do you mean ALL connections inside computer? strange I had same problem before building this computer and now only RAM exists from old setup) later this day or tomorrow. I have already installed real-tek drivers twice.
  9. Posts : 11,424
    No just the headphone/speaker connections and if this is a carry over then likely the issue is with the phone/speakers and it's cable.
  10. Posts : 9
    Windows 8.1 64bit
    I have tried with two headsets,
    Drivers should look fine?
