No sound
  1. Posts : 47
    win 7 and vista
    No sound
    hi guys . i have another problem and you have always sorted it for me. what a forum this is , great.. i have no sound. the drivers ok and it says that the device is working perfectly. the start up sounds work ok but there is a red cross over the speaker in the toolbar thingy.. i did a troubleshoot and it came up with the sound might be switched off in windows.. anyone explain where that is and how i rectify it..many thanks in advance.................................unit is a sony vaio vgn-fj3m
  2. Posts : 18,415
    windows 7 home 64bit
    Hi there ... Are the Function Keys working ? .....
  3. Posts : 47
    win 7 and vista
    no function keys not working..many thanks
  4. Posts : 18,415
    You need to Download the Vaio Event Service ....
  5. Posts : 47
    win 7 and vista
    thanks i will have to leave you there got to nip out many thanks ..simon
  6. Posts : 18,415
    No problem Simon .. Catch you later
  7. Posts : 47
    win 7 and vista
    hi its me so it is, im back. i downloaded the event service and it didnt do a lot. the updates it found are in xp becuase this laptop is old but ive brought it back to life.. if it was a driver problem which ive had on another laptop i found that the drivers wernt available for this old model so i was able to use the vista disc to get it running but this time it says drivers ok and working properly but could be switched off by windows.. i was wondering if theres something in the bios which is turned off but i suppose cause it plays start up dittie that cant be it.. any thoughts....many thanks sj
  8. Posts : 18,415
    Start search Type Sound ... Any thing in the Settings that can be changed ? ...
  9. Posts : 47
    win 7 and vista
    you lost me there.. can you break that down for my simple brain please thanks
  10. Posts : 18,415
    Click Start in the Search type Sound ... In sound Settings see if you can change any thing ...
