"Realtek HD Audio Manager has stopped working" at Windows Startup
  1. Posts : 1
    Hello, this is my first post here on this forum.
    About a week or two, I Downgraded my Computer (Dell l502x) from Windows 8 to Windows 7 Ultimate 64 Bits, installed the drivers from the Dell Page, and everything worked good, except for the Realtek HD Audio Driver Version 6.0.1.6312 (Recommended for my PC on Dell Website), This is the problem:
    When I Start my computer, a message shows up with the following error: "Realtek HD Audio Manager has stopped working" and then, I Have to close the message and open Realtek HD Audio Manager again from the Control Panel. I Have already tried re-installing Windows and the error keeps appearing After I Install that driver, I Was wondering if maybe that version of the driver is faulty or something (It would be weird, since it's the one Dell recommends for this computer on the page)
    I Have visited many forums, including this one looking for a fix to this issue, but I have not found a solution yet. So I was wondering if someone had this issue before and has a solution to this annoying problem.
    any Help would be appreciated, Thanks.
    Here's a picture of the issue im having when I start Windows 7 (It's in Spanish, but I think you will understand it)
    Try the R275 version on the RealTek site. Its the latest version and will work on your PC. When you run the Realtek installation the first thing it will do is uninstall the current version you have installed and then restart the PC. After the restart it will continue and install the R275 version. This is the version I have on all my PC's for both Win 7 64 bit and Win 8 64 bit.
    Download the High Definition Audio Codec R.275 64 bit OS version.
    Realtek
    BTW, here is the info on posting screen shots on this forum. You con't have to upload them to a host.
  3. Posts : 496
    Windows 7 SP1 Home Premium 64bit [x64]
    Realtek
    when visiting that link, you must click the check box to accept the license agreement and then click the Next button to get access to the R2.75 driver, which by the way has Realtek HD Audio driver v6.0.1.7246. newer than v6.0.1.6312 provided by Dell.
